Radio wiring install question (72)
Trying to hook up my retrosound stereo tonight and it was going well until it came to the point where I needed to hook up the speaker wires. The problem? There aren't any to hook to, lol. I have yellow, red (although it's from a yellow, aftermarket harness was previously installed), gray, and black, which are all used for the power/ground/etc.
There is wire that looks like speaker wire but it simply goes from the left side over to the right side...it doesn't make any sense. Basically
green/black speaker wire coming in on left------------------spliced together with uncolored speaker wire----------->exits right side
Does that setup make any sense to anyone? It seems like should cut the connection between those two and wire it up. The other question is, how many speakers are there supposed to be, 2 or 4?
Sounds like Bubba might have been there before! To my knowledge, there should only be 2 dash speakers mounted to the bottom of the dash pad. No speakers in the rear, unless someone added some previously. To be safe, I would try to follow the wires to each dash speaker so you know what you have. Once you confirm the correct wires that are connected to each speaker, next you will need to figure out which wire is the positive and which is the negative. A good way to figure this out is to take a "D" type household battery and attach some short wires to the + and - of the D battery. From there, you can connect these leads from the D battery to your confirmed speaker wires (this will not damage your speakers). While doing this, the speaker cone should push upward, this will indicate you connected the D battery to the speaker wires correctly. If the cone of the speaker pulls downward, then you should reverse your connections. This method will help you figure out which wire to the speaker is + & -. If the wiring is really butched, I would highly suggest you run new wires to each speaker. Hope this helps some.
I have a Tacoma that had a XM antenna on top of the truck. The wire had been routed to where the old tuner was. When he sold it, he just cut the antenna wire and left everything in place instead of taking five minutes to get rid of everything.
