Reconditioning my standard column and have a couple questions.
1 - Shaft threads are beat up a bit but savable. I need to know the thread size and count so I can get the correct chaser and straiten them out (this where the nut secures the steering wheel).
2 - I have about a 1/16 sideways and up and down play (not in and out) in the top bearing. Should this bearing be replaced or is there play in this area?
I do have and read Jim Shea's papers as well as the AIM. Neither gives me the shaft nut and thread size or the play tolerance.
Thanks for the input.
Reason: Changed play dimension
PLEASE SEE THE FOLLOWING THREAD FOR CORRECT INFORMATION.
I finally found a Saginaw column drawing with the threads called out. The nut would be a 9/16-18 UNF thread all the way to 1978. Then the thread was changed to metric and was M14x1.5-6g.
Jim
I'm sorry, I was wrong on the 1968 C3 Corvette standard column steering shaft thread. I did not realize that standard (non-adjustable) and the telescoping columns for the 1967-68 Corvettes had different threads:
On the standard (non-adjustable) columns the thread were 1/2-20.
On the telescoping columns the threads were 9/16-18.
Jim thank you for yor response and I'd like to thank peterman as well. I also am still a little confused on the replacement of the lower bearing. I don't see any detailed instruction as there is for the upper. Am I missing something as I read the papers or is there another paper explaining the procedure?
See this ebay link for a picture of the upper bearing. 67 & 68's are the same part tele or std. The bearing is pressed in the aluminum housing making this a pricier part.
Whats your question about the lower bearing?
This is my ebay auction but I'm posting it to show the part for discussion. I also have posted a shaft on ebay if you need to look at it also.
Thanks Corkguy I will find your ebay post and take a look. There is no link here. I was wondering when I get the upper hub off and cam will the shaft slide out from the bottom of the column exposing the lower bearing. Looking at it last night, I have a new issue. The PO installed a after market wheel and the hub has me scratching my head on how I will remove it and not damage any orther parts. I barrowed a wheel puller but it have the 1/2"x20 thread adapter. So it's of no use to me. I am sure I will figure something out it is only a steering column.
Do what you can to avoid replacing the lower bearing if you can save it. They are very difficult to find and nobody that I am aware of makes an exact replacement. I did find a functional replacement from Long Island Corvette. They deal mostly in C2's but the '67 and '68 columns are very similar. Once installed you can't see the bearing anyway. I believe the play you are experiencing is due to the upper bearing which is available.
FWIW: The lower bearing is press fit into the column tube. I'm pretty sure the steering shaft just slips through it (it's been a long time since I had mine apart). If you do have to remove it be careful not to strike the column too hard. The column is designed to collapse in a collision and it will deform if treated too roughly.
Thanks for input. I did get the upper column apart and have replaced the bearing. But I can not get the shaft out it will move about 1" and stops. It feels like there is a retaining clip inside. I did find a lower bearing for replacement. But if I could get away with greasing the bearing I guess I'm ok with that. It was the upper with the play. The bottom bearing does not seem to have any sideways play but I think it should be lubed somehow. Any ideas?
