1973 Seatbelt Buzzer/Light
Extremely novice electrical terms would be appreciated.
The system used in 72-73 works by having the retractors provide continuity when the belt is fully retracted, without the retractor connected, it will not provide continuity, and your light/buzzer will never come on.
My retractors were a rusted hump, and I replaced them with aftermarket retractors without the electrical connection. But I wanted the belt warning system to work, so I purchased the much easier to get, and much cheaper, later receivers with the electrical connection. These will work, but the receivers provide continuty when the belt is connected, which is the opposite of what the 72-73 retractors do, so I needed to add a couple of relays to reverse that.
