sbc vs bbc build price
O yea I do own a 550hp classic stang,,, did I just say that
You gotta figure the big block "grins" into the equation - those that can't be wiped off your face when you either 1)open the hood to show your power plant, or 2) mash the loud pedal.
But if a cheap 454 lands in your lap, there's no replacement for displacement!
The machine shop doesn't car if its big or small block, it all about the same for machine work. Stock replacement parts, pistons, cam, bearings, gaskets, ect.... Are about 30% more and that's on the high side of pricing.
A sbc with the good stuff can make good hp but youll never get the brute torque you will with the cubes of the BBC and thats what makes a street car fun. hp/rpm motor get expensive real quick!!
If you are looking for more HP then that, the SBC build costs will shoot up high real quick...and a BBC becomes more cost effective.. This depending on the quality of parts you use, the rate the machine shop charges for machining and assembly and how much of it you do yourself.
A 600hp SBC will cost more then a 600hp BBC..
Remember you also have to factor in the conversion costs of the BBC stuff.. (Brackets, pullies, headers etc etc).
Stick it in your car and run 10s on pump gas.... DONE.
But yes, the BB brackets, pullies ext ext will eat your budget alive.. Not to mention the good water pump, better radiator...ext..
I did the conversion and its quite expensive.. But then again, a well built SBC that makes 600+ HP will cost you $10-12k so.... It's almost a toss up sometimes...
The big block is very streetable and can still run good ETs with highway gears and a tight converter.
much easier than a small block.
I had the same experience..
I ended paying an easy $10,000 not including the EFI I added. As Alan said, it may be best to buy one already built from a pro engine builder who has his own shop. Shops can usually get all the parts much cheaper than what you or me can get them. On top of that we have to pay for all the machine work labor and what not...
I strongly disagree with the comment that there is hardly a difference in cost between building a BBC or a SBC. Things like the damper, rotating assemblies, lifters, rocker arms, valves, studs, valve covers, intake manifolds, headers, etc, etc, etc... They are cost more.. I would be willing to bet with just the parts mentioned there would be close to if not more than a $1,000. If SBC costs $10,000 to build, thats a difference of 10%.
If my goal was 500 HP with either a traditional SBC (gen1) or BBC, I would turn that 350 into a SBC 396 (4.03 w/ 3.875 stroke). You would have the ups of BBC such a HP, TQ, size, and you wont be burdened with the extra weight. Not only that, you can save money reusing some of the parts you already have.
Now lets look at my 454....
270 HP from the factory. Are you kidding me?? (Its a 72 motor) OK, I get it, smog control choked the hell out of them, but 270??? Now what will it take me to get this engine to produce another 150 HP like I did with my small block? Carb, exhaust, cam,...AND....A set of heads...AND pistons.....heads ALONE will run me at least 2 grand.
So, my meager point is that while a 454 is a great starting point to compare to what a mild 350 will perform like...getting a stock 454 to 'perform' costs far more than a small block. Dollar for dollar, HP is cheaper with a small block.
we went from bubba braggin hp to "as installed" hp in 71....
