Problems, front lower BJ's, and spring rates???
at that time I put in a new set of lower ball joints.....and now am finding out they have failed for the 3rd time, and now going on set #4....ready to work on it tmrw.....
I am suspecting that the lower joints are being worked to death by the stiff spring, I have another spring set from an 80-82, Chris McDonald gave them to me years ago, and I dunno the spring rate, just know that they are way taller than the ones in the car....
SO, while I"m at it strikes me, I would like to lower the car an inch or so, so goes anyone know how much to trim off the springs to drop the front down a bit, I intend on backing the nutz down in the rear by an inch or so.....
maybe even remove that plastic spacer between the plastic spring and the diffy, and put it under the plastic spring so the stack up remains the same....
any particular heat problem from the diffy that maybe affect the spring???
I do have 460 lbx VBP springs, and want to lower the car an inch or so....
I also have a stock set of 80-82 shark springs that I could maybe use....but would have to cut them to lower the car....
Let us know what you find out.
My lower balljoints are still original and also still fine, with exception of the drivers side one, which showed 0.5 mm of play in the checkup a month ago. I do have a shock-tower brace though and no composite spring (yet).
The 550's lowered the car to a little less than one inch of space between top of the tire and bottom of the wheel well. But they are pretty 'stout' to drive around with
so to orient them into the car and lower the front, IF I have to change the joints in there now....which is to say I am going to a place with a GOOD local rep and see just WTF is going on there....
