Stray Wire in 81 dash?
Old Feb 24, 2013 | 10:20 AM
SIXFOOTER's Avatar
SIXFOOTER
Default Stray Wire in 81 dash?
Getting ready to in stall my dash after several years. Found a stray wire. Orange wire, main dash harness passenger side at the corner. It has a socket that looks like it came out of a connector, but none of the connectors are missing a wire.
Ideas?
Old Feb 24, 2013 | 10:25 AM
SuperBuickGuy's Avatar
SuperBuickGuy
cig lighter?
Old Feb 24, 2013 | 10:32 AM
commander_47's Avatar
commander_47
Orange is usually a power wire.
If it is on the passenger side, behind the dash, in the corner.....it could be the glovebox light. There should also be a black ground wire not connected to something. This would be the ground.
Your glove box light should be a switch with a push button and the bulb as part of it.
It could also be the courtesy light down by the fresh air duct. Again, look for a disconnected black wire.
Old Feb 24, 2013 | 10:40 AM
SIXFOOTER's Avatar
SIXFOOTER
Got the glove box light, ctsy light and everything else ID'd in there, this one was hiding behind the harness and I didn't see it until I was ready to put the dash pad in.
All the connectors are full.
Grrr...
Old Feb 24, 2013 | 12:38 PM
540 vette's Avatar
540 vette
Is it hot all the time or is it switched power.
Old Feb 24, 2013 | 06:56 PM
SIXFOOTER's Avatar
SIXFOOTER
I did some checking, it gets power from the CTSY fuse. From the books I have it looks like a second power for the door locks depending on the options for the car. I taped it off since it didn't look like it was required anywhere.
Thanks for the help
6
Old Feb 25, 2013 | 07:59 AM
commander_47
Might be the vanity light. The mirror has two wires that run to a T plug on the right side of the glove box.
Old Feb 25, 2013 | 09:10 AM
MIKE80's Avatar
MIKE80
Sounds like it might be out of the connector for the "Courtesy Light Delay Timer" unless if your delay is working properly.
To Stray Wire in 81 dash?
