76/80 frame advice/interchange
http://www.71corvette.com/frames.html
since the 76 been sitting for 15 years (outdoors maybe?) and has a rusted out frame I think you have two parts cars.... part them both out and buy a better car
All of the body mounts, are in the same location, on both frames. The front and rear frame ends, and front suspension, are all the same. You'd probably need to use the 76 shocks for the rear bumper, as the 80's are a different diameter, and the 80's are a bit shorter too. You'll also want to use all of the 76 bumper supports and brackets.
You'll need to use the 76 gas tank and gas tank support, since the 80 support is shaped different and mounted further forward, than the 76's support. The tank supports threaded mounting holes, in the frame, will need to be re-positioned, to use the 76 support.
The only other issue I can think of, would be the transmission crossmember. The 76 crossmember, has holes in it, that the exhaust system goes through. On 80's, the crossmember doesn't have the holes, but instead is just pinched down on the right hand side, so the pipe will go under the crossmember. If both cars are automatics, this won't be a big deal. Automatic cars use a bolt in crossmember, and you can swap the 80 crossmember, for the 76 piece.
If the 80 frame is for a manual, the crossmember will be welded in. In this case, it may be easier to use an 80 exhaust system, than to cut out and weld in, the 76 crossmember.
Now to the bigger issue. If the frame is so rusted out on the 76, have you checked out the rest of the car???
A car sitting outside long enough, that the frame needs to be replaced, likely has other rust problems. Have you checked the windshield frame, and a-pillars, for rust. The frames often leak around the stainless trim, causing the frames to rot out. When this occurs, it often causes rust issues in the cowl and door hinge area (the birdcage). The t-top bar is also known to rust out.
What kind of shape are the floors in? 76's have steel floors, and due to the t-tops and windshield leaking, they often have rusted floors. The rocker/sill area is also prone to rusting out.
If your 76 has additional rust issues, it probably isn't worth putting the time and money into. There are just too many reasonably priced good 76's out there, to make it worth while to end up upside down in a rust bucket.
