joubs 81 corvette
Old Feb 27, 2013 | 03:04 AM
joubs's Avatar
joubs
1st Gear
Default joubs 81 corvette
Need help. I keep blowing the tale lamp fuse when i put on the head light switch.Its a new switch.This is my second one.I thought the first new switch was bad so bought the one that in the car now.Still same problem.The weird thing is my head lights work but nothing ells does that works off the switch.
Old Feb 27, 2013 | 05:07 AM
540 vette's Avatar
540 vette
You have a short in that circuit and need to check the wiring. Get a wiring diagram and then you can trace it out.
Have you done any work recently in those areas of the car.
Old Mar 1, 2013 | 08:20 PM
PaPaPork's Avatar
PaPaPork
Switch will not cause the fuse to blow as it is a "short" itself. I would start by ohming out from fuse box to light socket ( with switch in ON pos) and back to ground to try isolating the problem further.
Or do a hardcore version - hard wire the fuse location and look for smoke
To joubs 81 corvette
