Radiator Inlet Nozzle
Old Mar 2, 2013 | 03:15 PM
roger3's Avatar
roger3
Default Radiator Inlet Nozzle
I have a Dewitts Radiator in my 76. the inlet neck has (2) diameters. The radiator hose fits snug around the larger diameter segment. Anyone know the reason for the 2 different sizes?
I am thinking of cutting off the smaller portion. When my engine is running I have some bubbles/foam and it runs hot at highway speeds.
Seems like the smaller neck would significantly restrict flow and introduce turbulence, causing some foaming.
Roger
Old Mar 2, 2013 | 03:35 PM
77C34SPD's Avatar
77C34SPD
Just installed mine a little while ago. I looked at that and said should I? so I did.. Cut it at the height of the ridge.
Old Mar 2, 2013 | 04:13 PM
mds3013's Avatar
mds3013
Later cars used a smaller radiator hose. My '77 uses the larger size and on my Dewitts I did not cut off the smaller neck. Car runs to the thermostat themperature even when it is 105 degrees outside. mike...
Old Mar 3, 2013 | 10:59 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The folks at DeWitt's can answer your question.
Old Mar 3, 2013 | 11:43 AM
qwank's Avatar
qwank
My '81 fit on the smaller part
To Radiator Inlet Nozzle
