Spindle damage
Old Mar 3, 2013 | 10:26 AM
AvRog's Avatar
AvRog
Default Spindle damage
Have a hacked up front spindle. gonna change them both and bearings.
Any thoughts, warnings........
Thanks, Rog.
Old Mar 3, 2013 | 11:09 AM
Mooser's Avatar
Mooser
I don't think anyone makes new spindles so they are all "reconditioned"
What's actually wrong with yours?
Is there something else that needs fixed?
How are the hubs?
Buy decent bearings (Timken) and seals (CR)
Mooser
Old Mar 3, 2013 | 12:52 PM
doctorgene's Avatar
doctorgene
Yes Sir; I would only replace the one bad Spindle, Yes if the ball joints need replacing, now is the time to replace them, When you change one side, it is time to do both. along with the A- arm bushings. Use a hole saw to remove the bushings from the A-arm. Hammer & chisel if you have no access to Air tools, for removal of factory rivets. Used heavy hammer with A 1 1/4 " inch, nipple & Cap to reset them in the cleaned & painted A-arms. I chain off the springs to prevent a wild spring release. Be very careful releasing the spring. If you have not done this before, do a lot of reading, or find someone that has worked on A frt. end rebuild. Use good Jack stands. Look up proper torque on all bolts. Not an easy job, but very doable at home, if you have the time. Starting Around a Thousand Labor & material to have it done some where else. Be Safe, Gene
Old Mar 3, 2013 | 12:58 PM
spdrcr29's Avatar
spdrcr29
Look up "Corvette Mack" on ebay. He tends to have used spindles listed on a regular basis. His prices seem to be very reasonable...
Not sure what year you are looking for, but here's one of his spindles listed right now
http://www.ebay.com/itm/CORVETTE-FRO...31498a&vxp=mtr
Old Mar 3, 2013 | 02:56 PM
AvRog's Avatar
AvRog
How are the hubs?
Mooser
The right side has had a torch taken to it. There is metal missing (cut) and heated to the point of being blue.
I'll take a closer look at the hub.
Old Mar 3, 2013 | 03:01 PM
AvRog's Avatar
AvRog
I have everything apart, getting ready to put back together. I have new A arms and ball joints already.
I will take a close look at the other spindle to see if it can be reused.
You strted off by saying only replace the damaged unit. What are your concerns besides cost?
Thanks Rog.
Old Mar 3, 2013 | 03:03 PM
AvRog's Avatar
AvRog
Thats great and a decent price too.
Old Mar 3, 2013 | 03:51 PM
AvRog's Avatar
AvRog
Crap! Looks like he won't ship to us Terrorists here in Canada
Old Mar 3, 2013 | 03:57 PM
Mooser's Avatar
Mooser
Yeah, I've noticed that.
Check with Kens Corvettes and see what he has laying around
Mooser
Old Mar 3, 2013 | 04:51 PM
AvRog's Avatar
AvRog
Mooser
Will do
Old Mar 5, 2013 | 07:18 AM
AvRog's Avatar
AvRog
Thanks much! Mack has 2 and I have ordered.
Later, Rog.
Old Mar 5, 2013 | 07:45 AM
Mooser's Avatar
Mooser
So Mac will ship up to us after all?
Mooser
Old Mar 6, 2013 | 10:39 AM
AvRog's Avatar
AvRog
Mooser
Yup, he had to change the conditions on ebay, but its done!
To Spindle damage
