control arm interchange
Old Mar 4, 2013 | 06:35 PM
Arkyvette's Avatar
Arkyvette
Default control arm interchange
I have discovered a crack in my drivers side lower control arm at the leading edge going towards the spring pocket. It has lowered that wheel about an inch and is growing fast and I parked my vette until I can replace it. I contemplated welding it, but not thinking that's a wise choice and I'm surely not getting a core return if I buy from a vender. What year control arms are direct bolt in? I am ordering a suspension kit next week so good timing on pulling it out. Thanks!
Old Mar 4, 2013 | 06:41 PM
Marlin's Avatar
Marlin
I think all C3's used the same front suspension for the most part.
The front lower control arms are listed as fitting 64-82 from what I can see.
Old Mar 4, 2013 | 06:55 PM
Arkyvette's Avatar
Arkyvette
Thanks, that's what I was hoping, but wanted to see if there were any differences at all.
Old Mar 4, 2013 | 07:56 PM
Arkyvette's Avatar
Arkyvette
A corvette junker near me quoted 125 bucks for an old arm with no crossbrace.. Good price?
Old Mar 4, 2013 | 08:58 PM
gcusmano74's Avatar
gcusmano74
Look it over carefully first.
Or Mid America Motorworks. 604-497. And your local auto parts guy could get you the bushings.
Old Mar 4, 2013 | 09:29 PM
Arkyvette's Avatar
Arkyvette
I'm ordering deluxe USA parts front rebuild kit from Wilcox. I wish I could just get the reconditioned arms and do it all in a weekend, but its not in the budget.
Old Mar 5, 2013 | 07:24 AM
Marlin's Avatar
Marlin
Seems a little high but if you need it quick then maybe ok.
I thought they were going cheaper at eBay. Also check the FS section here, you never know.
Old Mar 5, 2013 | 07:35 AM
Street Rat's Avatar
Street Rat
'68-'82 are the same. You can find them on eBay for as low as $25 an arm most of the time. I just checked and $99 was the lowest price at this time. Plenty available.
Old Mar 5, 2013 | 09:24 AM
gbvette62's Avatar
gbvette62
Though there may be some very minor differences, on some of the a-arms used on early mid-years, all 63-82 arms are interchangeable.
$125 seems a bit strong to me. You can get re-built ones; already blasted, painted, and with new bushings and ball joints installed, for around $175 exchange.
The rebuilders usually pay $50-$75 for cores, so you really shouldn't give much more for a-arms either.
Old Mar 5, 2013 | 09:42 AM
Arkyvette's Avatar
Arkyvette
If I thought they would give me core credit for a cracked and now bending arm, I would just save myself the trouble and get a refurb arm. I doubt they would consider a cracked arm to be rebuildable. I really wanna know what kind of bo duke action caused it to crack, and kind of glad my car can't talk.
Old Mar 5, 2013 | 11:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Google the part number for the control arm. It's possible the same arm was used on several GM models and may not be unique to Corvette.
Old Mar 5, 2013 | 01:06 PM
Arkyvette's Avatar
Arkyvette
Thanks mike, that's advice I often forget. I did get my plug wires cheaper when I ordered them for an hei truck. They fit and function fine. People hear corvette and dollar signs start blinking.
Old Mar 6, 2013 | 07:19 PM
loup68's Avatar
loup68
Army
Mike you are right and beat me to it. I remember reading that GM, to save money after spending a fortune on making the IRS on the 63, took the A- arms off of a full size chevrolet, but put the left on the right side, ect. The arms went forward on the full size car, and ours point to the rear. I think that this is in the book, Corvette: America's Star-Spangled Sports Car, by Karl Ludvigsen. Lou.
Old Mar 6, 2013 | 08:50 PM
gbvette62's Avatar
gbvette62
I don't believe that the Corvette arms, are interchangeable, with any of the passenger car ones. The Corvette stampings look similar to the full size 58-64 arms, but I think the placement of sway bar brackets and the stops are different.
The part numbers for the Corvette upper and lower arms, are different than any of the passenger car ones, that I can find.
Old Mar 6, 2013 | 09:43 PM
Arkyvette's Avatar
Arkyvette
I also couldn't find any interchange info. I figured the sway bar would be the difference anyhow. I do wish we had a more affordable tubular arm setup available. I am contemplating buying all four arms, rebuilding them, then swapping mine out and selling them off. That would give me less downtime.
Old Mar 7, 2013 | 01:05 PM
Easy Mike's Avatar
Easy Mike
I only suggested checking to see.
Old Mar 7, 2013 | 09:15 PM
72LS1Vette's Avatar
72LS1Vette
I'd check vendors like Willcox, VanSteel, and ZipCorvette before buying an old control arm. For not much more $ (like $20) you can get a new or reconditioned arm with the crossbrace and new bushings.
Rick B.
To control arm interchange
Old Mar 7, 2013 | 09:22 PM
Arkyvette's Avatar
Arkyvette
You need to send them a rebuildable core to get that price. Double it without a core.
Old Mar 10, 2013 | 12:21 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
Saw your thread today, and I took my control arms off my '79 a couple years ago, replaced with vbp suspension pkg + and aluminum uppers. The car had about 54k miles on it when I took them off.
The arms are in the attic collecting dust and if you would like them you can get them all or just what you need for the price of shipping. I live in the Tampa Bay area so shipping shouldn't be that bad.
Old Mar 10, 2013 | 01:29 PM
Arkyvette's Avatar
Arkyvette
You got it! I will pm you and we can work it out. Thanks!
