Quartz Clock Conversion
Old Mar 5, 2013 | 04:53 PM
Brcmpbl's Avatar
Brcmpbl
Default Quartz Clock Conversion
If I do a quartz clock conversion in my 1976, do I need to supply power to it from a hot wire going into the cluster somewhere? Just not sure how this all looks.
Old Mar 5, 2013 | 04:55 PM
Shark Racer's Avatar
Shark Racer
No changes in wiring are needed. You simply replace the mechanism.
I did this last year, one of the easier things I've had to do. Make sure to free up the brass clutch mechanism and test it off the car with a 9V battery.
Old Mar 5, 2013 | 05:18 PM
Brcmpbl's Avatar
Brcmpbl
Great, thanks. Thought I was going to be splicing into something for juice.
Are you happy with the function of the new mechanism?
Old Mar 5, 2013 | 05:27 PM
my 76 ray's Avatar
my 76 ray
I bought the entire quarts clock. It fit perfectly and keeps perfect time.
Old Mar 5, 2013 | 05:56 PM
Shark Racer
I am happy with it, although I do miss the "ticking" of the electric movement.
Old Mar 5, 2013 | 06:03 PM
Roughrider's Avatar
Roughrider
I installed one of the quartz clocks in my '69 (and in the '78 I owned) and it was an easy replacement...and it works! Not like the original clock.
A bit of advice...when taking the panel out to replace the clock, do yourself a favor and replace every light bulb back there. It saves having to do it again later, the bulbs are cheap and the less often you need to take things apart in the car the better!
Old Mar 5, 2013 | 06:08 PM
Shark Racer
Agreed on the bulbs... and test all the socket/bulb pairs with a 9v battery too.
Old Mar 5, 2013 | 06:28 PM
Mooser's Avatar
Mooser
One last little thing I might put out there.
Before re-installing everything, check the hands.
I made a mistake and put mine all back together and back into the car and only then did I notice that the little hand is off about 20 min. So when it should be 4:00 the little hand is part way between the 4 and 5 while the big hand is on the 12.
Just irritating enough that I'll have to take it back out and fix it.
Mooser
Old Mar 5, 2013 | 06:41 PM
Brcmpbl's Avatar
Brcmpbl
Great info guys, thanks.
Roughrider, that's one nice Riverside 1969 you've got.
Old Mar 5, 2013 | 08:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Brcmpbl if you hang in there.. this is one of the next videos we have planned in the next month... Hopefully we can walk everyone through this conversion show a few tricks, and discuss issues that can show up during the installation. A good example of this would be the clutch....
Old Mar 6, 2013 | 10:40 AM
Brcmpbl's Avatar
Brcmpbl
Thanks Willcox, I'll hang tough for at least a month...will be that long until I'm back in the same province as my 76 anyway.
Old Mar 6, 2013 | 10:43 AM
MrJlr's Avatar
MrJlr
I bought the conversion kit from Willcox....
Minor PITA because I'd never done it before and the instructions left a little to be desired....but all and all - doable....and IT WORKED when I was done !
Old Mar 6, 2013 | 07:09 PM
loup68's Avatar
loup68
Army
I think that Corvette Magazine has a conversion article on their web site. Lou.
Old Apr 28, 2013 | 04:48 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
I just did this one mine, and it failed. No movement, and the thing started to heat up and smell like it was burning.
Waiting to speak to Willcox about returing for a replacement.
Ugh....
Old Apr 28, 2013 | 04:59 PM
augiedoggy's Avatar
augiedoggy
Ugh....
Could it be the polarity of the wiring was reversed?
Old Apr 28, 2013 | 05:17 PM
DucatiDon's Avatar
DucatiDon
No. I was testing it on the bench with a motorcycle battery.
Old Apr 28, 2013 | 05:37 PM
0Willcox Corvette
Former Vendor
When the movements start up they will run backwards, then forward and then backwards a few times before starting, this is normal.
It's odd that it is smoking... Did you verify that the clutch is not stuck from the old movement? If the old clutch is locked up it will cook the movement because the gears can not turn.
The link below was turned off because I'm on the last edit of the video... It should be up in about 1 week. But here is a copy of the instruction sheet (and one you can actually read). For anyone interested:
Quartz Installation Instruction Sheet ( A read-able copy)
http://willcoxcorvette.com/repairand...lp.php?hID=331
Willcox
To Quartz Clock Conversion
Old Apr 28, 2013 | 09:45 PM
DucatiDon's Avatar
DucatiDon
Well, I had it installed correctly, the original instructions were fine. but I went ahead and loosened the clutch up some more. Same thing....
Then I figured I had nothing to lose, so i switched the leads....
And it works fine! So is the quartz internals wired backwards? Are the instructions wrong? I dont want to install it and have the car burst into flames.....
Old Apr 28, 2013 | 10:29 PM
0Willcox Corvette
Former Vendor
Wow.. I have never seen that before.. I've been installing this same kit for twenty plus years.... that is only the second one I've seen bad.. ...
Tell you what.. you send it to me.. Clock and all and I'll install it for you with a new movement and return ship it the same day it arrives.... This way you won't have to worry about the time wasted installing..
you may email me at Support@Willcoxcorvette.com
Old May 10, 2013 | 05:21 AM
TurboStitchCW's Avatar
TurboStitchCW
A little off topic, but would anyone here have an extra clock housing for a 77? I broke one of the retaining tabs off of mine and the clock is loose and contacting the gauge cluster housing causing a short. I'd rather replace the housing than keep on buying new printed circuit boards.
