Clutch fan test ??
Old Jun 17, 2002 | 12:20 AM
Stevo81's Avatar
Stevo81
Default Clutch fan test ??
Please let me know how to test a fan clutch...I have one now that spins for about ten seconds after engine is shut off and I understand that means it is not good..? If I go to junk yard, engines will not be running...is there a way to test them by hand? thanks
Old Jun 17, 2002 | 12:35 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Clutch fan test ?? (Stevo)
I cant think of a test you can run on an nonrunning engine accept to make sure fan does not wobble on the shaft and fan turns somewhat freely.
Old Jun 17, 2002 | 12:44 AM
kenincanada's Avatar
kenincanada
Default Re: Clutch fan test ?? (Wightnite)
A stiff turning fan will sound like a wind tunnel when you race the engine
Old Jun 17, 2002 | 03:15 AM
noxqsz's Avatar
noxqsz
Stevo;
The only reliable test of a fan clutch is the method you describe. Besides that, you'll be very lucky indeed to find a fan clutch worth having in a wrecking yard. It's one of those parts that should be replaced with a new unit. Even if the yard you get the used clutch from lets you get another if the one you get is bad, you still get to go through the replacement process again. And again. And again. IMO, you're wasting your time with anything but a new unit.
Old Jun 17, 2002 | 07:17 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: Clutch fan test ?? (kenincanada)
mine sounds like that...thats good...right?
Old Jun 17, 2002 | 09:58 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Clutch fan test ?? (SIGNGUY)
I thought that when the car is cold the fan should be harder to turn. Once the car is up to temperature the clutch/fluid should allow the fan to turn easier.
Am I all wet here?
Old Jun 17, 2002 | 10:26 AM
Neo Fender's Avatar
Neo Fender
One rule of thumb (finger actually) that I read once.....
Spin the fan with one finger (make sure the engine is off :rolleyes:). The fan should NOT spin more than two revolutions. Mine turns only about once.
I agree, 10 seconds after shutting down is WAY too long.
Old Jun 17, 2002 | 10:40 AM
Ben Taylor's Avatar
Ben Taylor
Default Re: Clutch fan test ?? (Eddie 96)
You have that backwards, when the clutch gets hot it locks up, and when it's cold the clutch is loose. So if you turn the car off before it gets hot your fan will spin for a while. If you turn it off after it gets hot the fan should stop almost right away.
To Clutch fan test ??
