1976 Window Regulator / Motor Help
Old Mar 6, 2013 | 02:33 PM
rgpta's Avatar
rgpta
Default 1976 Window Regulator / Motor Help
I recently took apart the side windows in the car to replace internal components. With the door off I plug into the the window motor and nothing happens. When I re-installed the regulator I had to manually compress the spring to catch the motor gears. I put the window in and wanted to test prior to putting the door back on.
I am guessing it doesn't matter if the door is on the car as I expected the window to go up and down either way.
Any help appreciated. Is there a fuse for the electrical windows, relay, etc, I may have blown?
Old Mar 6, 2013 | 02:36 PM
MrJlr's Avatar
MrJlr
The motor has to be grounded....the wires are positive only...
Old Mar 6, 2013 | 02:41 PM
rgpta's Avatar
rgpta
thanks for the quick response. How is it grounded when the door is on versus off?
Old Mar 6, 2013 | 02:55 PM
MrJlr's Avatar
MrJlr
The motor grounds to the door when it's bolted in....use some wire and alligator clips or something...anything just to ground it...
To 1976 Window Regulator / Motor Help
