Tem sensor
Old Mar 7, 2013 | 10:38 AM
Iron_dog's Avatar
Iron_dog
Default Tem sensor
Hi,
does anybody know what is the purpose of this sensor? Mine seems to be disconnected...
Old Mar 7, 2013 | 11:17 AM
Paul L's Avatar
Paul L
Coolant temperature sensor, stock location.
Old Mar 7, 2013 | 11:58 AM
my 76 ray's Avatar
my 76 ray
It grounds the signal from the temperature gauge so the temperature gauge works.
Old Mar 7, 2013 | 12:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Iron_dog
...Mine seems to be disconnected...
Your Temp gauge isn't working either.
Old Mar 7, 2013 | 04:22 PM
Iron_dog's Avatar
Iron_dog
mmm... it is working... but it seems to me that this sensor is connected with ony ine wire, is it ok?
Old Mar 7, 2013 | 04:26 PM
Paul L's Avatar
Paul L
One green wire is fine but if it is disconnected (you said it was) and the gauge is working then there is some home-made wiring to another sensor somewhere else. Usually on top of the intake manifold
Old Mar 7, 2013 | 04:40 PM
Jig A Low's Avatar
Jig A Low
nope, that is the temperature switch that turns on the electric fan on the radiator
the temperature gauge sender is on top of the manifold near the gooseneck where the thermostat is.
Old Mar 7, 2013 | 04:44 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Not on a '74 corvette it is not. That is the stock location for the coolant temp sensor for your temp gauge on your dash. There was not an electric fan, only thermostatic.
Old Mar 7, 2013 | 06:49 PM
Paul L's Avatar
Paul L
Sorry, but you are incorrect. You are thinking of a C2. If it was on the passenger side near the back cylinders that would be the TCS (transmission controlled spark) switch.
Old Mar 7, 2013 | 10:18 PM
my 76 ray's Avatar
my 76 ray
Old Mar 8, 2013 | 09:02 AM
Easy Mike's Avatar
Easy Mike
...seems to be disconnected...
it is working... connected with ony ine wire...
You've lost me. It's either connected or it's not connected. Your AIM page shows it is the temperature sensor.
Old Mar 8, 2013 | 11:36 AM
gerry72's Avatar
gerry72
As Mike wrote, your AIM page shows it to be the coolant temp sensor and the only thing that sensor does is make the coolant temp gauge move. Look at the FWD mark on the page. That is clearly the driver side of the engine. So, you're either showing the wrong AIM page and it is the TCS on the passenger-side head that is in question, or you have a coolant sensor mounted elsewhere on the engine.
Old Mar 8, 2013 | 02:30 PM
Jig A Low's Avatar
Jig A Low
ok, lets look at it closely shall we----- the drawing calls it out as a "SW" which is customary for "switch", unlike the temperature "sensor". also-- if you look at note #1 in the comments section of the drawing it says that the switch was relocated. if it's a two wire connection, it is a simple on/off switch, if it only a one wire unit--it works on resistance to ground which is supplied by the engine JMHO
Old Mar 8, 2013 | 03:09 PM
LeMans Pete
Jig, unfortunately that is not the case. That is the stock location for all C3s, as far as I know. This location was not relocated.
Note 1 may be specifically talking about relocating the alarm switch(?). Again, there were no electric fans on the corvette; therefore, no temperature switch.
Here is the temp sending unit that threads into the head at that location.
Old Mar 8, 2013 | 03:19 PM
LeMans Pete
I'm curious, did '74s have the TCS switch in the RIGHT cylinder head? Has the OP posted the wrong page of the AIM? That would be a two wire switch, and if this is disconnected, would obviously not affect his temperature gauge.
Old Mar 8, 2013 | 04:57 PM
Iron_dog's Avatar
Iron_dog
Guys, the drawing is correct, I'm pointing this item on the driver side. The wire that goes to this item has two wires, one of them is disconnected... Temp gauge is ok, also the engine is not the original one but a crate one...
Old Mar 8, 2013 | 05:02 PM
Jig A Low's Avatar
Jig A Low
NOT all C-3's, My '81 has a factory electric fan and the switch for it is located in the drivers side head, the sensor for the coolant temperature is located on the intake manifold just adjacent to the thermostat goose neck, maybe the engine he has was pulled from a later model vette and they just left that switch in place
To Tem sensor
Old Mar 8, 2013 | 05:21 PM
Paul L's Avatar
Paul L
The auxiliary electric fan was not available in 1974. When used in later C3s, it took temps from the old 1974 TCS switch area on the passenger rear side.
Old Mar 8, 2013 | 05:23 PM
Paul L's Avatar
Paul L
My guess is that the car does not have a 1974 front wiring harness.
Old Mar 8, 2013 | 05:47 PM
LeMans Pete
The drawing is correct for a stock '74. If you do not have a stock '74 set up, then this drawing is not worth a whole lot to you.
Have you found another source for the temperature gauge, maybe on the manifold as some have suggested? Do you have electric fans? Any pictures of your engine bay?
