Coilover Shocks?
Old Jun 17, 2002 | 08:10 AM
Brutus's Avatar
Brutus
Default Coilover Shocks?
I was wondering whether the standard rear shock mounts would be sufficiently strong enough to handle coilovers.
I'm getting ready to install a fibreglass spring, but was tossing up whether coilovers might be a more viable solution depending on the degree of modifications needed ... if any. I could possibly see that a stronger/thicker top mount bolt might be called for, but what of the standard lower mount? Will it hold up?
Any thoughts or experiences?
Old Jun 17, 2002 | 08:36 AM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Coilover Shocks? (Brutus)
I don't think the lower stock shock mount will hold. It is just a small "D" that will end up turning. In coil overs they weld another mounting point on to the trailing arms. The top mount is also angled slightly so the shock will be loaded off center or one side of the rubber will be squashed more then the other. I have a set of coilovers and was looking at this this spring and decided to leave it till next winter. If it was as simple as just bolting it on I would have done it.
Old Jun 17, 2002 | 10:23 AM
Brutus's Avatar
Brutus
Default Re: Coilover Shocks? (norvalwilhelm)
Thanks Norval. I knew I could count on you for a sensible and informative answer. It was just an idea for the moment, but something I'd thought about for a while now. Looks like another project for the future.
I'm still fine tuning my 6 link so I won't get too carried away with any other ideas just yet.
Old Jun 17, 2002 | 10:34 AM
norvalwilhelm
Brutus. I just sent you 3 pictures of coilovers. I didn't post them here because I would have to load them first etc etc.
Hope they help with ideas.
Old Jun 17, 2002 | 11:09 AM
Brutus's Avatar
Brutus
Norval...Thanks for those pics. I can see what you mean about the 'D ' being a concern with this installation. I'd be very interested to see what can be done to better this situation. I'd give it some more thought but I'm heading for bed now.
Looks like the glass spring goes in for now at least. Thanks.
Old Jun 17, 2002 | 04:25 PM
73-454's Avatar
73-454
Are coilover shocks avaliable for the front, if so do you have a part number or where to buy. thanks
Old Jun 17, 2002 | 06:17 PM
Darkness's Avatar
Darkness
Default Re: Coilover Shocks? (73-454)
I'm thinking about the same,
Putting coilovers all around would be somewhat cheaper or at worst the same price as getting new suspention stuff from VB and other companies.
I've seen on the web that a set of 2 koni coilovers cost around $200-$300, seen this it's better than just getting a new fiberglass spring that costs $300+
Paul
Old Jun 17, 2002 | 07:40 PM
71roadster's Avatar
71roadster
I was recently looking at the QA1 website. The HAL shocks are highly regarded by the street rod crowd and most of the major magazines. They are easily adjustable and can be configured to pretty much bolt into our cars. The question is, can the upper shock mount built into the frame and the lower mount built into the A-arm support the entire weight of the front of the car (and then some in corners)??? I hardly think so. The upper and lower mounts would have to be considerably beefed up. I'll bet if someone called tech support at QA1 they could provide more information about the support requirements. I would really like to do this on the front. You could use variable rate springs and adjust the height to get the front end just right.
check out http://www.halshocks.com/shocks/vettesuspension.html
I'll bet this can be configured into a coil over type body and have top and bottom mounts that will fit the existing shock mounts. There is also http://www.halshocks.com/shocks/procoilsystems.html which will probably fit our cars, but again puts the entire weight of the car on the bottom mount.
Chris
Old Jun 17, 2002 | 08:41 PM
73-454's Avatar
73-454
Default Re: Coilover Shocks? (71roadster)
I guess we are talking different coilovers. I am looking for a pair of shocks with springs around them, just to help out the tired front springs. I still what to maintaine the front stock springs.
Old Jun 17, 2002 | 08:45 PM
Twin_Turbo's Avatar
Twin_Turbo
http://www.acp-euskirchen.de
Look in the bildergallerie -> zubehor
There are pics of Koni double adjustable aluminium (I tihnk 62 series) coil overs w/ brackets & mounted on C3's. Pretty simple bracket too!
Those shocks are around 350$ from Summit.
Marck
[Modified by Twinnie, 6:46 PM 6/17/2002]
To Coilover Shocks?
