big brake problem
Old Mar 8, 2013 | 09:24 AM
glenn c6's Avatar
glenn c6
Default big brake problem
I have a 73 roadster w/ manual brakes, ,just change trailing arms, had rear calipers off for a few days,put calipers back on,manual bled,no luck, motive power bled, ran 2 Qts off fluid thru whole system , 4 wheels still no air bubbles at all, no pedal, I have no leaks, good calipers and still no brakes, any suggestions??
Old Mar 8, 2013 | 09:33 AM
MrJlr's Avatar
MrJlr
Are you bleeding ALL the bleeders? I missed/forgot the inboard bleeders on the rear one time.....felt pretty silly.......
Old Mar 8, 2013 | 10:14 AM
glenn c6's Avatar
glenn c6
only 1 bleeder on each caliper
Old Mar 8, 2013 | 10:22 AM
myk7's Avatar
myk7
Pretty sure the rears have 2 on each caliper
Old Mar 8, 2013 | 11:26 AM
my 76 ray's Avatar
my 76 ray
Yep, the rears have two bleeders. One on the inside of the rotor and one on the outside. The inner bleeder needs to be bled before the outer bleeder or you won't get the air out.
Old Mar 8, 2013 | 01:06 PM
bashcraft's Avatar
bashcraft
Nope.
Yup.
Old Mar 8, 2013 | 02:29 PM
MrJlr's Avatar
MrJlr
There ya go.....I'm guilty of the same thing a few years ago.....
Old Mar 8, 2013 | 03:30 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
We've ALL forgotten the 2nd one on the rear calipers, at one time or another....
Old Mar 8, 2013 | 04:15 PM
71scgc's Avatar
71scgc
When the calipers were off did the MC go dry?
Old Mar 9, 2013 | 10:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Two bleeders on the rears; one for each caliper half. One bleeder on each of the fronts.
Old Mar 9, 2013 | 08:04 PM
gcusmano74's Avatar
gcusmano74
Yes. Absolutely.
Old Mar 11, 2013 | 01:07 AM
illenema's Avatar
illenema
Power bleed from the bleeders to the master, use about 15Psi, the portioning valve thinks something is wrong, need to trick it.
This is the only thing that worked here. it did work
Old Mar 11, 2013 | 06:24 AM
MrJlr's Avatar
MrJlr
To the OP......did you ever get it worked out?????
Old Mar 11, 2013 | 08:30 AM
glenn c6's Avatar
glenn c6
Yes, fixed 2 minutes after I bleed second rear bleeders, I knew they were there but never thought you needed to bleed both,your right, I feel dumb, but job complete, THANKS ALL
Old Mar 11, 2013 | 08:33 AM
MrJlr's Avatar
MrJlr
Awesome.....
Old Mar 11, 2013 | 06:15 PM
leadfoot4's Avatar
leadfoot4
Yes, fixed 2 minutes after I bled second rear bleeders, I knew they were there but never thought you needed to bleed both,your right, I feel dumb, but job complete, THANKS ALL
To big brake problem
