NHRA legal solid rear convertion help needed
NHRA rules say stock mounting points and must use the transvers spring and that isnt a problem but i am stumped on the trailing arm to rear, is the trailing arm bored out and pass the solid rar tube trough then welded? is there a top mount to control the rear?
i cant use a 4 link for the class. so it has to be this way...
NHRA rules say stock mounting points and must use the transverse spring and that isn't a problem but i am stumped on the trailing arm to rear, is the trailing arm bored out and pass the solid rar tube trough then welded? is there a top mount to control the rear?
i cant use a 4 link for the class. so it has to be this way...[/QUOTE]
What class are you trying to set it up for? NHRA Stock or Super stock?
It would help knowing whether the car is being set up to run NHRA Eliminater class's or just be NHRA legal for the ET.
Are you asking how to attach a solid axle to the original trailing arms?
If so you can't. What the rules state is that you must use the original control arms mounting points. You do this by using the original type of control arm, rear transverse spring AND Half shafts. You will need to run half shaft safety loops. (2) per side, plus a drive shaft safety loop.
This can be mounted to the rear cross member at the front of the drive line. Rules will state a position relative to the forward u-joint.
Overly Stiff rear spring, adj. bump stops, double adjustable shocks, rear cross member support pads, something to eliminate camber gain and upper links that remove the load on the half shafts. Just of few of the techniques use to run the IRS and keep it class legal.
Post a clearer example of what you are trying to do in the Drag race section. I think you will get more defined feed back once it is understood what you are trying to accomplish.
Dave
This keeps everything mounted off original frame mounting points.
