Show me your modified solid tranny crossmembers?
to make it easy on the exhaust pipes, I cut out the bottom section of the loops, and cut it wide on each side, then boxed in the open ends of the frame and built a small bridge structure in the top of the curved section, for strength....
the removable section has a 2" angle iron welded to each end, that rides on the top/rear of the stubs, plus a smaller welded piece under it, this forms a strong flange that is held to the stubs with a 1/2" bolt going fore/aft.....
my way, 6 bolts total, and the entire exhaust system is on the ground....4 more bolts and the cross member is on the ground, shifter and all.....
I have a 200 4r in there now, it was a Muncie 4 speed....
spent more time driving the cross member over to my welder buddy's place than actually doing the mod work.....
Welded tubes to the cut out piece & bolted that to the X-Member.
simplier than welding ears on both ends .
.I like it and the brackets are cheap enough.
and opening up the bottoms of the exhaust loops, makes the pipes SO easy to drop, as mentioned above.....
