Mini Starter Questions??
Old Jun 17, 2002 | 07:49 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Mini Starter Questions??
It looks like the old starter is having trouble with the heat and zz4. I seem to have to tap it every once and a while to get it going. I am looking for a new starter and saw the gm bow tie unit. Has anyone used this on a 14 inch flywheel with the offset bolt pattern? How does it work? Does anyone using it have problems with heat soak? Any info and recommendations are welcome.
Mark B.
Old Jun 18, 2002 | 12:42 PM
Sigforty's Avatar
Sigforty
Default Re: Mini Starter Questions?? (Sigforty)
TTT anyone have any info??
Old Jun 18, 2002 | 05:36 PM
Gordonm's Avatar
Gordonm
I am running a GM mini starter. I got it for 100 dollars. It is used on the 502 motors so it will turn over anything I have. I have seen some guys get them off some truck motors and have good luck. Mine has no more heat soak at all. I am running a big flywheel also.
Old Jun 18, 2002 | 06:46 PM
Sigforty's Avatar
Sigforty
Default Re: Mini Starter Questions?? (Gordonm)
Is this the starter you are running? http://www.sdpc2000.com/cart.asp?act...d=698&pid=1286
Mark B.
Old Jun 18, 2002 | 07:14 PM
1980ZZ4's Avatar
1980ZZ4
I run the bow tie starter and so far, no problems. Of course, the mini starter is much further from the headers than the traditional bulky starter.
Old Jun 18, 2002 | 08:42 PM
Gordonm's Avatar
Gordonm
Default Re: Mini Starter Questions?? (1980ZZ4)
That would be the one. I got mine from redvetracr here on the forum. He had a couple on a special deal. He is out of them now. Mine works great. Sounds :cool: too.
Old Jun 19, 2002 | 09:27 AM
stickboy's Avatar
stickboy
I have some pictures and information about the ministarter I just put on my vette on this page http://www.corvettepages.com/ministarter.php
Old Jun 19, 2002 | 07:21 PM
BeachinVette's Avatar
BeachinVette
I just put one on my car today. It sounds different starting the car but that is all I can say right now. It has only been on for 2 hours.
Bob
To Mini Starter Questions??
