Lower control arm shaft removal
Old Mar 17, 2013 | 02:29 AM
bellaireroad's Avatar
bellaireroad
Default Lower control arm shaft removal
How difficult is it to remove the lower control shaft with the motor in? Will a socket fit on the bolt head that goes through the tab on the crossmember?
Old Mar 17, 2013 | 02:55 AM
Drawmain's Avatar
Drawmain
In a word, yes. I've done it before a couple of times.
Old Mar 17, 2013 | 06:56 AM
scottw's Avatar
scottw
It is not hard at all. Plenty of room. The only one that is hard is the upper control arm w/ the radiator in the way on the forward bolt. Not hard, just have to move radiator.
Old Mar 17, 2013 | 11:37 AM
bellaireroad
Thanks ...got the motor out and was looking at the bolt that connects the shaft to the crossmemember ....looked like it might be hard to get to with the motor in
Old Mar 17, 2013 | 11:59 AM
20mercury's Avatar
20mercury
Default Imho...
I can tell you my 72 rear lower control arm bolt was tough to get off after 40yrs.
IMHO, better to take it off or at least loosen it while you have more room.
To Lower control arm shaft removal
