idler arm 1982
Old Mar 17, 2013 | 09:17 PM
terry82's Avatar
terry82
Default idler arm 1982
i am needing to replace my idler arm on my 82.it looks easy enough, any thing i need to know?
Old Mar 17, 2013 | 09:53 PM
billcarson's Avatar
billcarson
go with the moog.it seems to be better able to stand up to the elements.compared with the original delco,which might come from who knows where now.
Old Mar 17, 2013 | 10:16 PM
qwank's Avatar
qwank
+1 for the Moog Heavy duty
Old Mar 18, 2013 | 05:10 PM
terry82's Avatar
terry82
is there a regular and a heavy duty.
Old Mar 18, 2013 | 05:51 PM
aaroncorvette's Avatar
aaroncorvette
HD -http://www.moog-suspension-parts.com/proddetail.asp?prod=MOOG-K6100
Old Mar 18, 2013 | 06:18 PM
terry82's Avatar
terry82
thats a good price for a good part.moog is good stuff thanks
Old Mar 18, 2013 | 06:36 PM
hugie82's Avatar
hugie82
Yes, make sure you pop the center link BEFORE you unbolt the arm from the car!!!
Ask me how I know.....
Old Mar 18, 2013 | 11:06 PM
gcusmano74's Avatar
gcusmano74
Just like any C3 project, you need to stock up on cusswords before you start to work. You don't want to run out of them before you finish the job. You'll be needing them.
Old Mar 19, 2013 | 05:16 PM
terry82's Avatar
terry82
are c3 cusswords differant than c1 c2 c4 c5 ?do we need a new sticky?
Old Mar 21, 2013 | 01:29 PM
Arkyvette's Avatar
Arkyvette
I JUST got mine off. Yes, pop the joint first. Then you can remove the nut from the bottom easily. The long bolt is a carriage bolt and the frame holds it. The top one on the other hand.... Its a PITA. At least with one person it is. I was able to feed both my arms down there with an offset wratchet wrench on the nut and a regular wrench on the bolt. Its one of those one click at a time deals. With two people you could have a helper hold the bolt up top while you can easily hit the nut underneath with a ratchet. Straightforward job overall though.
Old Mar 21, 2013 | 05:16 PM
terry82's Avatar
terry82
it may be spring on the calender but it is cold around here .its too cold too work on the car .
Old Mar 21, 2013 | 05:26 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by terry82
it may be spring on the calender but it is cold around here. it's too cold too work on the car .
I've been putting off a couple of "garage projects" for that very reason...
Old Mar 22, 2013 | 10:33 AM
Tom454's Avatar
Tom454
K6100 Moog... Rockauto... $37.79
Old Mar 22, 2013 | 11:27 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by gcusmano74
...you need to stock up on cusswords...
...are c3 cusswords differant than c1 c2 c4 c5 ?...
Cuss words are Corvette generic. Generation does not apply.
To idler arm 1982
