Caliper overhaul - piston pitting
Old Mar 17, 2013 | 09:49 PM
78SilverCam's Avatar
78SilverCam
Default Caliper overhaul - piston pitting
Good evening,
Making the rounds on maintenance and this is one of those, 'while you are at it...'s
Overhauling the calipers and I am trying to be frugal and safe. The caliper seems to be in good shape except for some irregular wear at the base/pit of the bore. And the pistons have some pitting.
Here is the question: Can I simply keep using the piston (and for that matter - the seal since it is still in good shape)?
The pistons have some pitting
Thanks again for your feedback!
(Edit - provided links as apparently I cant get the [img][/img] to work....
Old Mar 17, 2013 | 11:19 PM
redvetracr's Avatar
redvetracr
pitted pistons are JUNK...replace them ALL, if your calipers are not sleeved replace those also. I have some extra freshly rebuilt stainless steel sleeved calipers with o-ring pistons, if you or anyone else is interested send a PM.
Old Mar 18, 2013 | 01:15 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I had my brakes apart twice before I finally got off the wallet and got smart. New SS calipers and now I have good brakes and pedal and no more leaks.
Old Mar 18, 2013 | 08:24 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Pistons and seals aren't terribly expensive. Let me know if you are going to replace them, I would be happy to answer any questions.
Andrew
800-442-0335
http://www.muskegonbrake.com/corvett...r-piston-front
Old Mar 18, 2013 | 10:41 AM
SuperBuickGuy's Avatar
SuperBuickGuy
the pistons are available cheap from just about any auto parts supplier.
and to answer your question, no - they are not safe, they are now paper weights
Old Mar 18, 2013 | 12:15 PM
78SilverCam
Thanks for the feedback guys, appreciate it as always.
Looks like I'm gonna have to go new all over.
Pistons are about 50 per caliper, new calipers are about 400. So may as well get new.
Also lookin at replacing the rotors
Might get VBP Sports Pkg or some combo with the non-sports pack (saves about $300). (some plans to boost HP over time - about 50 hp or so) Question is, what point does the extra $300 become worth the money?
Old Mar 19, 2013 | 06:50 AM
muskegonbrake
Supporting Vendor
Not to be picky, but pistons only cost $16 per caliper, seal kits cost $10 per caliper. If you're going up in HP and are really ready to spend that kind of money you might consider the Wilwood D8-4's or D8-6's, that wouldn't cost much more than the kit you're looking at.
Andrew
800-442-0335
Old Mar 19, 2013 | 08:40 AM
78SilverCam
Looked at that, think I probably wasn't clear. I am budgetting $1,000 for the entire brake work.
4 calipers
4 rotors
Also looking for parking brake shoes and associated spring kit. If I can fit that under the $1,000 cap then all the better.
Understand that you can spend as little or as much as you want. I am simply, like everyone else, looking for the best quality/service for my money.
To Caliper overhaul - piston pitting
