Arm rest attachment
Old Jun 18, 2002 | 12:22 AM
Indy Year 25's Avatar
Indy Year 25
Default Arm rest attachment
The screw holes in the door brackets for my arm rests are over size. (I know it's hard to believe, but they are.) I was thinking of bonding a pieces of metal to the back side of the brackets with JB Weld. I think that would hold it allowing me to drill and screw. What do you think.
This also seems like an interesting product. http://www.por15.com/puttys.html
Or do you have "the" fix? I would appreciate your thoughts and experiences with this situation.
Old Jun 18, 2002 | 01:19 AM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Default Re: Arm rest attachment (Indy Year 25)
Another way to fix that problem is to rivet some sheet metal to fit over the holes and drill a new, smaller hole for a smaller sheet metal screw to fit in. It's probably a little cleaner than using JB weld and faster too. :smash:
Old Jun 18, 2002 | 02:35 AM
Stevo81's Avatar
Stevo81
Thanks...I have been going to ask that question...I am thinking rivets as the arm rest is used so much...
Old Jun 18, 2002 | 07:41 AM
1979toy's Avatar
1979toy
I used clip nuts on mine. U shaped sheet metal with a stamped "thread" in it, ask at the parts counter at the local auto parts store. It's tough to find the nuts with a deep enough throat to fit but worth the trouble. Now, if it pulls loose again I can just get new hardware and start over.
To Arm rest attachment
