High volume/flow water pumps
Old Mar 18, 2013 | 06:46 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Default High volume/flow water pumps
81, smogged, socal heat of summer, and A/C.
what are the thoughts about after market Water pumps?
Old Mar 18, 2013 | 07:09 PM
donyue's Avatar
donyue
Hi calwldlife, I would recommend the Edelbrock Victor series 8812 or 8822 water pump. They are high performance pumps and fit perfectly in our C3. I have one on my 427 SBC and it works very well. But I should advise that I am also running a Dewitts aluminum rad with dual spal fans so overheating should never be a problem for me. Here's a link to follow:
http://www.edelbrock.com/automotive_...igh_perf.shtml
I believe Weiand also makes a water pump that will fit but I don't have a part number. There is one other manufacturer that other forum members have used and recommended but can't remember the name of it.
I'm sure other members will advise on that.
Old Mar 18, 2013 | 07:11 PM
John 65's Avatar
John 65
From my own personal experience I say dont waste your money. I saw zero change from a unit called flow kooler that I purchased many years ago. If the rest of the system is up to snuff, the gm pump should do the job.
Old Mar 18, 2013 | 07:29 PM
Mike Ward's Avatar
Mike Ward
The GM is already about 35% 'oversized', more is not better.
Old Mar 18, 2013 | 07:42 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
This is true. I've had more negative news about so-called high flow water pumps than good.
Old Mar 18, 2013 | 07:49 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
The GM Pump is fine if everything else is working correctly. But there are ways to improve on the GM Pump that is DIY.
Old Mar 18, 2013 | 08:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
thank you
I have read similar over the years
that is curious. all gm small block or vette specific?
delco pumps or the auto zone variety?
interesting, you do have experience.
teach me.
Car never over heated. just runs hotter than I like.
210-220 ish .
any help in tips or tricks is wanted.
Old Mar 18, 2013 | 08:24 PM
SHAKERATTLEROLL
Yes that is too Hot in my opinion. What Thermostat are you running?
Do you have an air damn? And is all seals in place? If you have a clutch fan is it working correctly? If this stuff is in place and is fine then I would probably have your radiator cleaned out.
As for the Water Pump. What we did years ago before all of this new fangled fancy stuff is you would simply remove the back cover off of the water pump and make a round disc that is the same size as the impeller and center it and rivet it to the impeller then simply put the rear plate back on.
Old Mar 18, 2013 | 08:34 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
that is summer temps with A/C
normal is at 195 like the thermostat.
changed rads out long ago and the orig is still clean and
solid. the system is flushed and maintained very well.
all shrouds all there and the fan clutch seems good.
clutch is the only thing I never changed or messed with.
I check the pump blades and clearence it to the cover plate.
not aware of the rivet to blades trick.
Too cheap to go alumn.
and elect fans.
Old Mar 18, 2013 | 08:50 PM
SHAKERATTLEROLL
I would change the Thermostat to a 160F or 180F and drill 4 1/8 equally spaced holes in the body. This will help coolant flow and also help prevent air pockets.
I feel this would be the easiest Thing to do since all of your other components are up to snuff.
Old Mar 18, 2013 | 10:26 PM
Mike Ward's Avatar
Mike Ward
Pretty much all stock pumps on all cars. The temps your car is running is not far off how it ran when new. I wouldn't worry too much about it.
Old Mar 18, 2013 | 10:46 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
thanks, and yes, it runs a few degs cooler than new.
i am orig owner.
I want to use A/c more and just don't like the extra temp.
Old Mar 18, 2013 | 10:54 PM
gcusmano74's Avatar
gcusmano74
Please allow me to disagree.
If you drill a bunch of bypass holes in the thermostat, in cold weather it will take forever to warm up. Somebody did that to a '95 C2500HD pickup I once owned. Warmup time in the winter went from 5 minutes to 25 minutes. The factory 'stat has a VERY small air bleed in it. It's fine. Leave it alone.
And a 180 F temp thermostat is perfect. IMHO, a 160 F is not hot enough. The thermostat only sets the minimum operating temp of the engine. The efficiency of the pump and radiator establishes the maximum temp. Likely, even with a very low temp thermostat, the water will eventually stabilize at 180 to 200 degrees anyway. A low temp stat will only increase the warmup time. And a cold engine wears faster and burns more fuel. The C5's and C6's run at 220 or thereabouts.
Old Mar 19, 2013 | 05:01 AM
SHAKERATTLEROLL
I will not argue the points. Except to say that the OP lives in CA so maybe he does not get cold winters. I live in San Antonio TEXAS of which we do not really have winters to contend with. Heck one does not even need a choke lol.
But yes as far as cooling efficiency goes a thermostat will only regulate the water flow at its set release state. And is designed so that it can slow down the water flow at its set temperature as to let the radiator have enough time to cool the water flowing through it. That is why it is a Bad idea for a Street engine to not use a Thermostat.
Now then if the flow rate is at Maximum rate then if the radiator does not have enough efficiency to cool down the heat generated by the engine than the water temperature will steadily climb to the temperature that the system is able to hold it at.
But I would choose a 180F Thermostat to start with. If you wish you do not need to drill 4 holes but I would at least drill one 1/8th inch hole.
And these Engines are not a C-5 or C-6 Door Stops lol.
Old Mar 19, 2013 | 07:05 AM
noonie's Avatar
noonie
The reason for the 1/8" bypass holes in the tstat is for when the internal bypass of the smallblock is closed off, system needs some circulation.
Some high flow pumps have that port missing. Reason for this is to have ALL the coolant going thru the radiator when the tstat is open and engine is at operating temp.
The current trend in thermostats is to use a bigger hole with a poppet to close it off (leaks slightly for circulation to detect coolant temp).
The bigger hole just minimizes possible air pockets from improper filling.
In a properly working system, the coolant should be able to maintain the tstat temp +/- a few degrees. A 195° is fine in almost all cases.
Most aftermarket high flow pumps have substantially more flow at idle where it's beneficial.
Higher flow results in greater heat exchange.
Alum rad will improve cooling too.
What GM did originally is irrelevant.
Old Mar 19, 2013 | 08:08 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I use a Stewart Stage 2 water pump with a 180* TS and original recored rad. It now takes a bit longer to warm up due to the small drilled holes in the TS. I'm happy with this pump/cooling but I live in an area where it doesn't get hot to often.
Old Mar 19, 2013 | 08:51 AM
noonie's Avatar
noonie
That's a very good pump, the one I use most and is one that has no port for the internal bypass, so you are forced to use a highflow balanced tstat with the extra holes.
To High volume/flow water pumps
Old Mar 19, 2013 | 09:05 AM
hugie82's Avatar
hugie82
Warm up between a 160* and a180* is the same up to the set temp. I ran 160* in my hotrods for years but in a stock corvette in the winter you'll have the choke engaging on the old style spring choke. Electric choke has no ill affects.
I do prefer to run a 180* as it hold the coolant in the radiator longer to cool in traffic and you do want your oil to reach 215* so it can steam out moister in the engine.
Water pumps I'm on the fence. If I were to spring for a pump the edelbrock is rebuildable from what I understand and a better design with larger bearings.
Old Mar 19, 2013 | 10:21 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I have had good luck with a Flow Kooler pump, an A/C fan and otherwise stock system in a 68 L36.
In CA we do not worry too much about cold weather.
Of course, I use full manifold vacuum advance and a little quicker than stock curve.
Just my experience...
Old Mar 19, 2013 | 11:45 AM
Belgian1979vette's Avatar
Belgian1979vette
Same here. Harder to warm up though.
