Rochester Quad 800 questions
Old Mar 18, 2013 | 07:16 PM
jackwabbit703's Avatar
jackwabbit703
Default Rochester Quad 800 questions
I just received this carb today. Does anyone know what this is and does it need to be plugged into a vacuum port?
Red arrow is pointing at it:
Thanks in advance.
Old Mar 18, 2013 | 07:36 PM
7t9l82's Avatar
7t9l82
yes , it needs vacuum to allow the secondary air door to open. normally don't look like that.
Old Mar 18, 2013 | 07:39 PM
jackwabbit703
Thanks for the info. Can the vacuum port for the secondary plug into another vacuum port that is not being used on the carb it self or do I need to "T" it off pvc line or something? FYI, this is stage 2 rebuild carb from Jet-P.
Old Mar 18, 2013 | 07:44 PM
7t9l82's Avatar
7t9l82
yes, any vacuum port should work.
Old Mar 18, 2013 | 08:03 PM
Shark Racer's Avatar
Shark Racer
I believe I found another picture of that - is there an extra port?
Old Mar 18, 2013 | 08:21 PM
jackwabbit703
Seems like size of the inlet is the same as size of the inlet for Vacuum canister port on the front of the carb.
Thanks again.
Old Mar 18, 2013 | 08:23 PM
jackwabbit703
[QUOTE=Shark Racer;1583399570]I believe I found another picture of that - is there an extra port?
The smaller inlet (which is pointing 90 degrees up in your picture) is connected via vacuum tube to a vacuum port right next to brake booster vacuum line on the back side bottom of the carb, right above the intake manifold. My older carb has the vacuum diaphragm and valve mechanism in the right front of the carb so, this one threw me off a little.
Old Mar 19, 2013 | 11:54 AM
Shark Racer
I honestly have no idea what the big port is for - does it pull vacuum when you hook something up? The smaller port has a measured restriction in it to delay the relaxation of the choke/secondary blockoff when vacuum drops.
I'd drop Lars a note to be sure.
Old Mar 19, 2013 | 01:34 PM
jackwabbit703
I called Summit Racing and they told me nothing need to be plugged into the big nipple port on the diaphragm. Secondary air valve vacuum line is already plugged in next to where the brake booster vacuum port.
Old Mar 19, 2013 | 02:40 PM
MelWff's Avatar
MelWff
that setup is shown in Cliff Ruggles book on the Quadrajet. The diaphram has two functions one to keep the secondary air valve from opening at cruise and idle and the second to act as a choke pull off. From this description I would say the choke will not crack open once the engine is started unless you attach a vacuum source.
Old Mar 19, 2013 | 02:45 PM
bpassmore's Avatar
bpassmore
Look in the port, I believe there is an adjustment for the secondary air valve.
Old Mar 19, 2013 | 03:19 PM
jackwabbit703
You just reminded me to look for his book in the basement. I've moved back in October and still have some unpacking to do.
I will also look to see if there's an adjustment in the SAV.
Thanks.
Old Mar 19, 2013 | 04:08 PM
Shark Racer
I think you may be on to something.
A simple test would be to apply vacuum to the diaphragm via the small port with the large "port" uncapped and verify that it holds vacuum.
I'm betting bpassmore is right, that the port is for adjustment of the arm.
Old Mar 20, 2013 | 12:03 PM
jackwabbit703
You are correct. Another Summit racing tech verified that is indeed adjustment port for the secondary air valve that can be adjusted by a 3/32 allen wrench. He recommended not tinkering with it and leave it alone.
To Rochester Quad 800 questions
