Crossmember removal question
Old Mar 24, 2013 | 11:30 PM
cwaynem's Avatar
cwaynem
Default Crossmember removal question
I almost have my differential out. Everything came off easier than I thought. All I have left is the cross member. On the photos I have seen posted, it looks like the rubber bushing comes off with and stays attached to the cross member. On one side, when I started helping it off, it looks like the bushing will stay behind. On the other side, I can't tell which is going to come loose first. Does it matter if the bushing stays attached or should I work on it to come off with the cross member?
Old Mar 25, 2013 | 03:01 AM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Yes the Bushings should come off with the Cross Member but if one does not then I would say to purchase a replacement set and install them.
