Holley set up 4150
Old Mar 25, 2013 | 01:53 PM
jtalka's Avatar
jtalka
Default Holley set up 4150
Hi;
I've made some progress with my ZZ383 and the Holley 4150 which sits on top... The car is running a set of McJack's headers and an Allen's chambered exhaust. the carb is 4150/3124 service replacement from my old '65 396..
I have the basics working fine... I need some help with setting up the vacuum secondaries.. I can get them to open fine but when they do there is a momentary flat spot where it takes a second or so before the full power is felt. There is no secondary accelerator pump.
The engine pulls 15" Hg at idle. Power valves are 6.5's front and back..
Can anyone give me an idea as to how to properly tune the secondaries??
Thanks,
Joel
Old Mar 25, 2013 | 03:40 PM
MelWff's Avatar
MelWff
You have to buy these two kits, from the factory that carb had a yellow spring
http://www.jegs.com/i/Holley/510/20-59/10002/-1
http://www.jegs.com/i/Holley/510/20-13/10002/-1
Old Mar 25, 2013 | 04:20 PM
gerry72's Avatar
gerry72
The yellow spring is what would be in the carb if that was the original application and it may work for this one as well. Get the spring kit and open the vacuum motor to see what spring is now in there. Too light a spring will give you a fast-opening secondary. You tune the secondary opening to the point where you can't feel the opening, meaning nothing apparent seems to be happening. When it opens too fast or too soon, there is not enough airflow in the booster to draw fuel and you get a bog. When the bog or lag in the throttle goes away, that is where there is nothing apparent in the opening.
Old Mar 25, 2013 | 04:28 PM
jtalka's Avatar
jtalka
Thanks guys... I'll pick up the quick change kit...
Old Mar 27, 2013 | 11:05 AM
scottyp99's Avatar
scottyp99
You don't really need the quick change kit, but if you've never changed a secondary spring, it's about a medium sized pain in the a$$ to do on the carb, in the car. It's not that hard to tear the diaphragm while re-installing it, too. For 17 bucks, it's money well spent if you are going to be playing around with secondary springs. Plus, it looks cool! Good luck!
Scott
Old Mar 27, 2013 | 02:32 PM
gerry72's Avatar
gerry72
Originally Posted by scottyp99
...Plus, it looks cool! Good luck!
Scott
If you want cool and convenience, then this is what you really want: http://www.quickfueltechnology.com/m...c-housing.html
Old Mar 27, 2013 | 02:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
Quick change kit worth it unless you get it right on the first try lol
Hate messing with anything more than just the lid
Old Mar 27, 2013 | 02:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I agree with the others.
the quick change is worth it for ease of spring changing.
good luck
To Holley set up 4150
