Starting problem after storage...
Old Mar 25, 2013 | 01:58 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Starting problem after storage...
Wanted to bring the Vette home from storage and she wouldn't start. The starter sounded like it was making a grinding teeth noise. Would it possibly be an elec. conection or is it possible the starter has loosend up? I didn't get to look at it closely because it's in a fairly dark garage. Any ideas?
Old Mar 25, 2013 | 03:37 PM
MelWff's Avatar
MelWff
You dont mention auto or manual but you could have some bad teeth on the flex plate/flywheel. Put the vehicle in neutral and try to turn the crank bolt with a socket a few degrees.
Old Mar 25, 2013 | 07:51 PM
jbaron's Avatar
jbaron
I'll check that out.
Old Mar 28, 2013 | 11:01 PM
jbaron's Avatar
jbaron
ttt
Old Mar 29, 2013 | 10:34 AM
gerry72's Avatar
gerry72
Sounds like the Bendix or the solenoid are sticking. Neither is either difficult to diagnose or fix. You'll have to pull the starter and bench test to see if the solenoid is fully travelling and moving the Bendix to the end of the nose housing. Of course, you could just replace the starter under the assumption that's where the problem is.
Old Mar 29, 2013 | 11:08 AM
diehrd's Avatar
diehrd
Could be as simple as a low battery
Old Apr 1, 2013 | 10:47 AM
jbaron's Avatar
jbaron
It was just a bad battery.
Old Apr 1, 2013 | 10:50 AM
diehrd's Avatar
diehrd
Your welcome ,
To Starting problem after storage...
