My first thread. Wooo Hoooo!!
Old Mar 26, 2013 | 12:56 PM
madam's Avatar
madam
Default My first thread. Wooo Hoooo!!
I've been reading many threads covering a variety of subjects. All I can say is I have found my favorite Corvette forum.
My question, I have recently purchased a driver 1976 L48 Auto trans. I would like to lower the front from 1 to 1-1/2 inches and am seeking advice as to the best approach.
Much thanks for your input.
Old Mar 26, 2013 | 01:14 PM
Learning_Curve's Avatar
Learning_Curve
Quite a few people switching to 550lb springs have found about an inch lower ride height. Other option is cut your current springs. There are a lot of threads on that subject. Remember, it's better to cut too little than too much...
Old Mar 26, 2013 | 01:20 PM
rogman16's Avatar
rogman16
Congrats and welcome to CF!!! Lots of great folks, mentors and info... "Search" will become your friend... I did a couple quick searches on "cut coil", "lower front", and "how to cut front coils"... You'll come up with a lot of threads and then you can peruse at your leisure... Here's an example of one of the threads...
http://forums.corvetteforum.com/c3-t...-too-high.html
Have fun and we LOVE pictures...
Rogman
Old Mar 26, 2013 | 01:32 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Welcome! We love pics.
Old Mar 26, 2013 | 01:33 PM
redman76's Avatar
redman76
St. Jude Donor '09
If it is higher than stock, you might check to make sure spring is seated correctly in the top pocket. It's possible if work was done in the past that it was incorrectly installed which would leave a large gap between tire and wheel well. Why are you trying to lower? I installed 550# spring on mine and it dropped it about an inch or so. Just be careful. These cars already sit pretty low, so you have to keep road conditions and low points on car (sidepipes, extra capacity oil & tranny pans, etc.) Lowering will also make it ride stiffer (which I like), but depends on your roads.
Old Mar 26, 2013 | 01:45 PM
MrJlr's Avatar
MrJlr
I would advise not cutting the spring....it was engineered as it is.....get a 550lb....
Oh - and welcome aboard !
Old Mar 26, 2013 | 02:30 PM
madam's Avatar
madam
Thanks for the reply. First Q. - What is the rating on the stock spring? I am assuming some thing more than 550 #. Also I have read a little about cutting springs and conflicting advise . . . Cut from the top or bottom??
Thanks.
Old Mar 26, 2013 | 02:51 PM
madam's Avatar
madam
Thanks, I will check for correct positioning in spring pockets first. I want to lower because visually the asthetic stance seems incorrect. Also I am a fan of Foose type of looks and currently the front of the car is higher than the rear. That I assume is due to the rear leaf setteling over the years. (and by the way the rear does not look squatty). I like the height of the rear and believe the front should be at least equal or just slightly lower than the rear hence the desire to lower.
As far as road clearence, thirty years ago I bought my first C3, a 1975. Great car that I owned for ten years so I now all about clearence and being carefull everywhere you drive. I sold the car and the boat I owned for a bigger boat (my first Formula) which is where I wanted to focus my play time. Now I'm 54 yrs old still very active own my third Formula, a 311SR1, and wanted to get back in a C3.
Thanks for your input.
Old Mar 26, 2013 | 03:31 PM
redman76's Avatar
redman76
St. Jude Donor '09
Hey we are the same age. Yeah, I've got the rake look on mine . . . the rear sits a little higher than the front.
Old Mar 26, 2013 | 03:39 PM
madam's Avatar
madam
Cool, and my 76 is also red.
Old Mar 26, 2013 | 03:42 PM
Welcome to the forum and good luck lowering the car.
Old Mar 26, 2013 | 07:40 PM
oldsarge's Avatar
oldsarge
Welcome and congrats on your new ride. Go have some fun with it for awhile and then you can have your way with it.
Old Mar 26, 2013 | 07:50 PM
billcarson's Avatar
billcarson
you have purchased the best looking year for corvettes so it is all good no matter which end is up.
Old Mar 26, 2013 | 08:57 PM
oldalaskaman's Avatar
oldalaskaman
cut one full coil off each front spring, worked perfect on my 76, one of the few free mods
Old Mar 26, 2013 | 10:05 PM
palmbeachvette76's Avatar
palmbeachvette76
My '76 sat like a Bubba 4x4 so I replaced the coil springs with the VB&P 550lb coils and 8" rear bolts. Before, during and after (with new paint color)
Old Mar 27, 2013 | 11:49 AM
madam's Avatar
madam
Hey Old Alaska Man, thats the method I'm leaning toward.
Now, cut from the top or bottom?? What is involved in removal of the springs, best method. Do you know of any links describing the proceedure??
Also, some say the ride will be a little stiffer which makes sence (fewer coils). Will it be uncomfortable stiff (granted its a personal preference issue)?? And will a new alignment be required?
Thanks,
Old Mar 27, 2013 | 12:40 PM
madam's Avatar
madam
Hey thanks for your comments.
I've been driving short distances when weather allows. You know, to analyze and get familliar and learn the new girls issues. Then on the weekends correct certain systems that need attention only to the point that I'm able to drive the following week.
Just having fun with it ya know.
Later.
Old Mar 27, 2013 | 12:59 PM
oldalaskaman
didnt notice any change in ride, cut mine from the bottom, if you cut the full coil, it will index just as it did prior
wilcox has a good video on the removal procedure as do several of the members
Old Apr 12, 2013 | 03:26 PM
madam's Avatar
madam
Wel I finally got around to the lowering job. Ended up cutting one full coil from the bottom of the stock springs.
Not really a bad job, just took some time and patience. I chose to try to break the upper ball joint loose by hammer tapping the flats that are cast into the stud body. First a couple raps on the left then right and back and forth. After around 8 - 12 raps pop!!! out came the tapered ball joint stud from it's bore and caught by the nut that I left on but loose.
Bottom line . . . exactly 1-1/2 inches lower and looks great. (to me) Nicely raked stance.
Now, due to the absence of much shimming on the drivers upper control arm shaft, I don't think the alignment shop will have enough positive camber adjustment to get there. Does anyone have an idea how much adjustment in inches might be needed to get the camber back where it was?? .062'', .125'', or more?? Has anyone used the offset Shafts and what would be a good source??
Thanks much.
To My first thread. Wooo Hoooo!!
