1975 factory alarm
Old Mar 26, 2013 | 03:18 PM
cor66vette's Avatar
cor66vette
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
Default 1975 factory alarm
Where might I locate a trouble shooting procedure for the factory alarm system on a '75 coupe? Thanks
Old Mar 26, 2013 | 04:36 PM
Peterbuilt's Avatar
Peterbuilt
I can't find a troubleshooting guide but you should be able to puzzle it out...
Start at the alarm horn, jumper 12 volts and a ground and confirm that it works.
Next go to the key switch in the fender and confirm 12 volts there and that you have continuity when the switch is turned 90 degrees.
From there check for 12 volts and a good ground at the anti theft relay.
Here's a basic schematic.
You may also have this switch which protects the alarm key cylinder.
The on line 75 schematic has no information about your alarm.
http://www.vetteprojects.com/bmv/mis...tte%201975.pdf
The 77 on line schematic has a diagram in it.
http://www.vetteprojects.com/bmv/mis...tte%201977.pdf
The relay and flasher are behind the passenger seat.
Do some testing and post back someone will walk you through it.
Regards, Pete.
Old Mar 26, 2013 | 05:31 PM
redwhitekat's Avatar
redwhitekat
Mine had power at the switch but the switch was bad bought new switch done mine also has underneath the hood contact that also activates the alarm just check for power. I have a 74 btw
Old Mar 26, 2013 | 07:28 PM
robert.sperry's Avatar
robert.sperry
I have repaired the alarm system on both my own 74' and my son's 74' and in both cases it was a bad key switch. You can jumper the switch terminals on the car and if the horn blows you know
the switch is bad (Note: to run this test you will need the hood or a door open).
Old Mar 27, 2013 | 05:27 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
This switch is the problem in many cases and is a good place to start troubleshooting. They are inexpensive and readily available from Vettes parts vendors.
Old Mar 27, 2013 | 09:42 PM
flaco1801's Avatar
flaco1801
Took me many hours but i finally found the bad wire...it was behind the carpet on the wall behind the seats...74
Old Mar 29, 2013 | 06:14 PM
cor66vette's Avatar
cor66vette
Regards, Pete.
I like that. My testing will commence this weekend. Thank you.
EDIT Alarm is fixed
To 1975 factory alarm
