Best Performance Mod for my 72:
Old Mar 28, 2013 | 08:53 AM
Mike Plummer's Avatar
Mike Plummer
2018 C5 of Year Finalist
Default Best Performance Mod for my 72:
I own a 72 base model with a turbo 350. I'm curious what mods provide the best bang for the buck without doing work on the short block or cam swap...bottomline things that can be done in my garage. changes I have already made include Hooker sidepipes and conversion to eletronic ignition...my goal has always been to keep the stock appearence or make changes that are reversable.
Thanks Mike
Old Mar 28, 2013 | 09:24 AM
gerry72's Avatar
gerry72
First, Mike, is if the car is as delivered, it should have a THM400, not a THM350. But that isn't relevant to your question. Just an observation.
I have only three recommendations in the "not too hard to do" category: 1) You likely have a 3.08:1 rear gear. Buy a 3:55 gear set, pull the differential and take it to a shop that can install the gears for you (assuming you aren't able to swap the gears yourself). This makes a huge difference in how the car accelerates. 2) A set of good-flowing heads -even without a cam swap- will significantly boost your engine's torque output. 3) Make sure the engine's performance is delivering at its peak. Meaning the ignition is up to snuff and is running a proper advance curve for your needs and that the carburetor has a good fuel curve.
Old Mar 28, 2013 | 09:12 PM
Mike Plummer
Thanks I never considered a rear end swap but it makes great sense. Thanks:th umbs::fl ag:
Old Mar 28, 2013 | 09:40 PM
iokepakai's Avatar
iokepakai
Best upgrade to my vette was the Richmond 6spd trans.Works great with the 3.08 rear gear.Total transformed the car! It's a blast to drive now and the 6th gear OD makes for great hiway cruising.Pricey but worth the expense.I could've changed rear gears but decided to use the funds for a new trans anyways.It's pretty much a bolt in with the G-Force cross-member and the driveshaft is same length as used on a TH350.Swap cost me close to 4500.00 with all new parts,and would do it again in a heart beat.
[IMG][/IMG]
[IMG][/IMG]
Old Mar 28, 2013 | 10:20 PM
68post's Avatar
68post
That Richmond looks to be a large trans. What's the weight dry/or wet ? Thanks.
Old Mar 29, 2013 | 12:39 AM
bluedawg's Avatar
bluedawg
A set of afr 180 cc heads. I say this because once you start its hard to quit.
Old Mar 29, 2013 | 12:51 AM
gkull's Avatar
gkull
Without touching the motor a manual tranny uses something like 25 HP less than an auto tranny
Old Mar 30, 2013 | 10:49 AM
bobbarry's Avatar
bobbarry
I'd say the best improvement/$$$ improvement you can make is to optimize the ignition-timing of the setup you already have using a kit like Crane's adjustable vacuum-advance kit:
http://www.cranecams.com/333.pdf
It's under $40 through the online speed-shops, and it not only allows you to change and limit the vacuum-advance, it also provides the springs and good instructions on altering the mechanical advance-curve as well. It takes you step-by-step through the process, adjusting one parameter (base, vacuum, centrifugal) at a time, until you've got the best curve that give you best performance with today's gasoline while eliminating ignition-knock.
Given the effects of time and "efforts" of previous owners, and the change in the properties of gasoline since our cars were built, it's unlikely your ignition-advance is optimal, so this may result in surprising seat-of-the-pants changes in how your car drives.
Old Mar 30, 2013 | 10:57 AM
aaroncorvette's Avatar
aaroncorvette
[IMG][/IMG]
[IMG][/IMG]
A trans swap is a must for a small block, it's a win win situation, better launch and an overdrive. ( Tremec 600RR)
In a small block car the 3 speed autos and 4 speed manuals are for the museum IMHO.
The best mod i've done so far, yes it's expensive but I'd do it again
Next time i'd buy a running Camaro and break it up for the 5 speed.
Old Mar 30, 2013 | 11:02 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mike Plummer
I own a 72...what mods provide the best bang for the buck without doing work on the short block or cam swap...bottomline things that can be done in my garage...
A good tune up.
Old Mar 30, 2013 | 11:06 AM
aaroncorvette
I reckon you could do the 5 speed conversion for free...
I bet it puts 2.5k on the value of the car, and if you was wise you could do it for that
To Best Performance Mod for my 72:
