Help with rounded bolt
Old Mar 29, 2013 | 07:37 PM
Motor City Vette's Avatar
Motor City Vette
Default Help with rounded bolt
Ugh...been trying to get my passenger-side rear caliper off and the two caliper bolts were looking pretty rounded. I tried a lot of Liquid Wrench and the 5/8 Craftsman wrench that's supposed to help with rounded bolts. Nothing but busted knuckles. You can't cut the bolt head off as the bolt would still be threaded into the back. Plus, I've got so much brake fluid and Liquid Wrench all over the parts that I don't want to use heat, either.
I was talking to my neighbor - who wrenches a lot on his car - and offered $100 if he could get them off. No take.
HELP!
Old Mar 29, 2013 | 08:40 PM
REELAV8R's Avatar
REELAV8R
If the bolts are accsessable enough then use a file or dremel grinder and put new flats on the bolts to get a six point socket on the bolts to loosen. Next size down English or metric doesn't matter.
Old Mar 29, 2013 | 09:06 PM
71scgc's Avatar
71scgc
Make sure your wrenching the right bolts. It's kinda easy to get on the bolts holding the caliper halves together, rather than the mount bolts. I've done it, sure many others have too.
Other than that, a rounded-bolt extractor and an impact driver...
Carter
Old Mar 29, 2013 | 09:17 PM
rafalc's Avatar
rafalc
drill them out
Old Mar 29, 2013 | 09:32 PM
lionelhutz's Avatar
lionelhutz
I would try to clean up the oil and use heat.
Old Mar 29, 2013 | 09:43 PM
lance m p's Avatar
lance m p
Default my 0.002 cents..........................>
with that one AND a lil heat. dremel preferably.
Old Mar 29, 2013 | 09:47 PM
Zorro O's Avatar
Zorro O
How long did you let the penetrating oil work. A day or two can make a big difference. Soak it then drill it and use an easy out. I know, it's easy to say and hard to do.
Old Mar 29, 2013 | 10:21 PM
Motor City Vette
No too long, just a couple of hours. I sprayed some more on and will let it soak overnight and then try tomorrow with an EZ out. Besides, my skinned knuckles could use the rest
Old Mar 29, 2013 | 10:26 PM
Hitch's Avatar
Hitch
I wouldn't worry about the fire from the oil. It will burn off, just keep a wet rag handy. That and an impact gun will free the bolt or break it. Either way you have removed the caliper...
Hitch
Old Mar 30, 2013 | 01:54 AM
mengelstad's Avatar
mengelstad
i have some irwin rounded bolt extractors hate to have to use them but they work good and about 50bucks a set...
Old Mar 30, 2013 | 03:34 AM
bluedawg's Avatar
bluedawg
I agree with fileing the head down just enough to hammer the next size smaller socket onto the bolt, this usually works for me. I've also used a hammer and chisel trying to hammer counter clock wise to get the bolt to spin. You could also try to easy out the bolt or reverse drill bit.
Good luck.
Old Mar 30, 2013 | 06:55 AM
Gordonm's Avatar
Gordonm
I work for Irwin's sister company so I have access to all of their tools. These work very well and are pretty much like doing the Dremel trick and going with another socket. These bite into the head of the bolt and extract the bolt. Little pricey for a one time use but they work.
Old Mar 30, 2013 | 12:20 PM
bluedawg's Avatar
bluedawg
On a 37 year old car theres no such thing as a one time use.
Old Mar 30, 2013 | 01:52 PM
Keesterdog's Avatar
Keesterdog
I would try a small pipe wrench. The harder you pull the tighter it grips. I think a wrench with strong sharp teeth would loosen a perfectly rounded bolt.
Old Mar 30, 2013 | 01:53 PM
Motor City Vette
WOOHOO! Got 'em off. Used a lot of Liquid Wrench yesterday and let it work overnight and then bought the Irwin Bolt-Grip extractors. Hammered on the Irwin extractors and then used a whole lot of leverage and muscle.
Man, what a PITA...glad they're all off, now I can put on the new calipers and bolts.
Old Mar 30, 2013 | 02:57 PM
rogman16's Avatar
rogman16
Success, very nice!!!
Rogman
To Help with rounded bolt
