fuel EVAP Test - failed CA smog test
Old Mar 30, 2013 | 07:31 PM
Snoopysvet's Avatar
Snoopysvet
Default fuel EVAP Test - failed CA smog test
Just failed the CA smog test, 1978 Corvette,L48, federal, how can I beat this test? It was a STAR test, I noticed he pinched a hose near the master cylinder, under STAR they cannot do repairs, they have some sort of machine that
Pressurizes the fuel system to run their test, everything else passed
Old Mar 30, 2013 | 08:50 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
vapor canister. 80 bucks
Old Mar 30, 2013 | 09:26 PM
babbah's Avatar
babbah
you would think by now that when a car is 35 years old that it would be exempt form the test. Used to be at 30 years old.
Old Mar 30, 2013 | 09:29 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I am on my third one.
not easy to change and a cheap azz
vacuum valve failed.
not serviceable.
Old Mar 30, 2013 | 10:01 PM
Snoopysvet's Avatar
Snoopysvet
Can I sleathly plug the hoses leading to the vacuum canister?
Old Mar 30, 2013 | 11:21 PM
Snoopysvet's Avatar
Snoopysvet
Vacuum canister or charcoal canister?
Old Mar 30, 2013 | 11:53 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
charcoal
make sure the number of hoses is right for your car.
Mine has 5
not sure how to plug a line to pass smog.
I know a sealed vacuum port on the canister leaked.
the sticker on the underside of hood will show the number of lines.
Old Mar 31, 2013 | 12:51 AM
Snoopysvet's Avatar
Snoopysvet
I have made sure the hoses are correct per pictures 1978 Chevrolet Service Manual, I suspect it is not holding pressure
Old Mar 31, 2013 | 01:41 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Move to a less screwed up state!
Old Mar 31, 2013 | 01:45 AM
Shark Racer's Avatar
Shark Racer
Some day...
Old Mar 31, 2013 | 02:39 AM
Snoopysvet's Avatar
Snoopysvet
Someday, but now I got to best this smog test
Old Apr 1, 2013 | 01:20 PM
Snoopysvet's Avatar
Snoopysvet
I may have found the culprit, did not have much time on Easter to trace the line
To fuel EVAP Test - failed CA smog test
