Rear Spindle installation
Old Mar 30, 2013 | 10:18 PM
Jonesy1's Avatar
Jonesy1
3rd Gear
Default Rear Spindle installation
I had an interesting issue with new spindle install tool from Ecklers. It's 1/8 inch short pulling in the spindle. Which loads the bearings and you can't apply the proper tq.
Anyone have ideas How solve without taking out the spindle?
Old Mar 30, 2013 | 10:20 PM
SuperBuickGuy's Avatar
SuperBuickGuy
as there's no pictures, please forgive the seemingly simple question
did you remove all of the spacers off the spindle tool before you put the first bearing on?
Old Mar 30, 2013 | 10:29 PM
Jonesy1's Avatar
Jonesy1
3rd Gear
The tool has a long threaded socket that screws onto the spindle end. A larger tube slides over that and has a nut onthe end that pulls the spindle into the bearing housing. No spacers. The problem is the tool bottoms out before the spindle is in far enough. It's about 1/8 inch short. If you tighten the spindle nut with 35 or mor lbs it loads the bearing. I have 73 Corvette
Old Mar 31, 2013 | 12:33 AM
wombvette's Avatar
wombvette
The regular yoke and spindle nut will pull it down the rest of the way. If it tightens up on the bearings, you have done something wrong with the spacers.
Old Mar 31, 2013 | 12:42 AM
Jonesy1's Avatar
Jonesy1
3rd Gear
I have the spacers correct, but I am worried about stripping the spindle nut. Thanks
Old Mar 31, 2013 | 11:08 AM
SuperBuickGuy
Spindle tool with spacer still on
spacer is between the bearings and spindle is assembled with bearings
view of the assembly from the 'back' or outboard side
To Rear Spindle installation
