Brake problems
Old Apr 2, 2013 | 10:55 AM
crash100's Avatar
crash100
1st Gear
Default Brake problems
I own a 1976 Corvette StingRay and have had it over 20 years. I have had continous brake problems. I have had it in the shop twice a year for over 20 years, but nobody, including a Chevy dealorship can fix the problem. I'm told this is a continuous problem with older vettes. I keep losing the brakes to where the BRAKE light come on when I apply the brakes and the brake pedal goes all the way to the floor. I have to pump the brakes in order for the car to come to a complete stop. I have replaced calipers, lines, master cylinder, you name it, but the problem persists if the car sits for awhile without being driven such as it sits two weeks or more. I need help to find a fix as I only have 83,000 miles on the car and it looks great. Can the brakes be fixed and can someone estimate the cost, because I want to drive it more than I currently do, but I feel it is unsafe to drive.
Thanx to anyone who can provide a positive response.
Rick
Old Apr 2, 2013 | 11:10 AM
MelWff's Avatar
MelWff
When you replaced the calipers did you use stainless steel sleeved? Did the new calipers use stock seals or O ring seals? The generic shops you went to, are they Corvette only, or the corner repair shop? Sounds like you should contact a local Corvette club and find out from them who they recommend for repairs.
Old Apr 2, 2013 | 11:12 AM
mikep3's Avatar
mikep3
If you are not loosing brake fluid, then:
Air in the system
Bad Master Cylinder
You need a good brake shop!
lvmyvt76's Avatar
lvmyvt76
how is the rotor runout???
Old Apr 2, 2013 | 11:24 AM
jb78L-82's Avatar
jb78L-82
As others have stated-air in the system!
Master cylinder, caliper seals leaking, and/or rotor runout.
I replaced my 66,000 mile 78 L-82 4 speed C3 calipers in 1985 with VBP stainless steel ones with REGULAR OEM seals (no lip seals back then) and I have never had a brake issue now in 28 years! The car sits 99.9% of the time, for many months over the winter-just took it out last weekend and everything like always is perfect with the brakes. Find the path of the air leak, fix it, and change the brake fluid every 3-4 years and you should be good to go.
Hope that helps!
Old Apr 2, 2013 | 11:41 AM
Mike Ward's Avatar
Mike Ward
I'll bet a six pack that some 'expert' replaced the rotors or removed them to have them machined thereby introducing surface runout.
This appears on this board so many times it's not funny.
Old Apr 2, 2013 | 12:35 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by lvmyvt76
...runout...
Originally Posted by Mike Ward
...runout...
You have posted classic symptoms of excessive runout.
To Brake problems
