1980 light problem
Old Apr 2, 2013 | 11:39 AM
twk1946's Avatar
twk1946
Default 1980 light problem
Before I changed headlight switch tail lights and interior lights worked. When I put in new switch interior lights did not work. I put in old switch and interior and tail lights did not work. I put in new switch and both still out. Head lights work fine. I changes fuses for tail lights and interior.
There is a black wire coming from fuse box with red connector that has white connector attached. white connector not attached to anything now. black wire goes into fuse box above tail light fuse with orange connector. Also have a black and a gray wire with a female connector with two prongs loose behind glove box.
