H pipe ??
Old Apr 6, 2013 | 03:46 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Default H pipe ??
We had my '77 on the lift this morning to do rear O-ring calipers
and we lowered it an inch w/ the 8" bolts that I bought last fall. While it was up there my mechanic who does excellent custom pipe work was scoping it out to see if I should buy the true dual conversion kit or just custom bend a 2 1/2" system. He said not to waste my money on the kit as it would be an easy custom build and that he wants to run about a 2" H pipe for better scavenging and thinks it will also have better sound. This setup makes perfect sense to me, what do the Experienced forum experts think?
PS The motor is basically stock w/ a rebuilt carb and rebuilt, re-curved distributer per Lars and Gorlich Accelerators mufflers, the cat has been gone for a while!
Old Apr 6, 2013 | 03:59 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Listen to your mechanic ref the 'H' pipe.
Old Apr 6, 2013 | 04:02 PM
drwet's Avatar
drwet
I think he hasn't actually bent up a system for a Corvette before. The kit from Corvette Central duplicates the factory system in every way, including all the little tweaks and crimps for clearance. There is no chance whatsoever that your guy will be able to do as well with a custom system, especially if you have lowered your car. Even with the kit, you are going to be challenged for ground clearance.
As for the H-pipe it will tone down the exhaust note - much more mellow. I'm not convinced it will make any difference in terms of performance.
Old Apr 6, 2013 | 04:05 PM
Rotonda's Avatar
Rotonda
True dual exhausts pepped up my stock 77 L48 (this was a LONG time ago). Headers helped more. (I now have an L-31 with a bigger cam plus a hot rodded TPI and a 700R4. The duals and headers remain.)
The H-pipe (which I installed after the headers & duals) evened out the exhaust and gave the impression it was more quiet.
Old Apr 6, 2013 | 04:17 PM
gcusmano74's Avatar
gcusmano74
An H pipe reduces the sound a bunch at higher RPM's. Not so much around town. I had to slightly richen the idle mix screws (1/8 turn out) after I had mine installed.
Old Apr 6, 2013 | 04:43 PM
BPHORSEGUY's Avatar
BPHORSEGUY
My car has been lowered 1" ( today ) and I should have mentioned it is a 4 speed with the 2 holes cut thru the crossmember where the right side and future left side pipe will go. I understand that automatics are different in this area. I do not under stand how the duals will loose ground clearance as it seems the future left side pipe will be exactly the same height as the right side. Please educate me if I am missing something or are you referring to an automatic setup which I have no experience with!
Old Apr 6, 2013 | 04:56 PM
BPHORSEGUY's Avatar
BPHORSEGUY
I want to do this primarily for sound. My car is not abnoxiously loud now but would never be mistaken for stock w/ the mufflers I have and cat removed! I want the car aggressive and rough sounding but not a kids car if you know what I mean. By "evening out " the sound do you mean it got rid of the "motor boat " sound? Do you think it got quiter or just an impression as you state and how much louder were the duals over previous setup and did you use the same mufflers??
Old Apr 6, 2013 | 05:57 PM
BPHORSEGUY's Avatar
BPHORSEGUY
[QUOTE=drwet;1583566167] Even with the kit, you are going to be challenged for ground clearance.
Okay, I have crawled under the car and realize the low point isn't near the crossmember. The Y pipe just before the tire carrier is only just less then 5" above the ground with the tire carrier being about a half inch higher then that. The pipes where they will go through the crossmember have more then 8" and of course are protected by the crossmember. These measurement are with the car lowered 1". I still think my guy should be able to do this and maybe even improve on this! If I am still missing something please educate me! I could always buy the kit later if this doesn't turn out as well as we think it will !
Old Apr 6, 2013 | 08:43 PM
7t9l82's Avatar
7t9l82
yes use the h pipe yes let your local guy do it . if there is a problem he is just down the street.
Old Apr 6, 2013 | 09:15 PM
Les's Avatar
Les
The H pipe evens out exhaust pulses and should give you a small bump in power. If your mechanic is used to building custom exhaust he'll have no problem taking care of you.
Old Apr 6, 2013 | 10:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
Hes full of it car will run the same and your wallet will be the only thing scavenged. People love to throw around big technical words to sell you stuff.
Old Apr 10, 2013 | 03:11 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Vizard has a different opinion about that than you do. He says it's a 100% probability of reduced noise, a 60% probability of increased horsepower, and 0% probability of reduced performance .
As an engineer I'm more inclined to believe (fellow engineer) Vizard's claims than other people's claims to the contrary.
Old Apr 10, 2013 | 03:30 PM
Les's Avatar
Les
There are plenty of other sources who agree with him. I've been too busy to engage in a debate over it, so I decided not to respond.
Old Apr 10, 2013 | 04:04 PM
jb78L-82's Avatar
jb78L-82
H and X pipes absolutely will sweeten the tone and help the HP. H pipes have been used for a kazillion years by hot rodder s going back to the 70's and just about every car manufacturer today that utilizes true duals utilizes an H/X pipe of some sort-It's NOT for show! My 94 Mustang GT Convertible had an H pipe from the factory and I replaced the H pipe and cats with a magna flow X pipe with high flow cats and boy does it sound sweet at high RPM. The L-82 has 2.5 duals with McJacks shorty headers with no H pipe simply since the kit did not include one.
Old Apr 10, 2013 | 06:16 PM
7t9l82's Avatar
7t9l82
actually , Chrysler engineers working on the max wedge program determined it was worth horsepower. that obviously applies to cars with full exhaust. oh yes that was about 1961 or 62
Old Apr 10, 2013 | 06:56 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Who agree with who???
Old Apr 10, 2013 | 07:21 PM
Les's Avatar
Les
With 69427 when he referenced what Vizard says. Bottom line- there is a benefit from crossovers, either via H-pipes or X-pipes.
To H pipe ??
Old Apr 10, 2013 | 08:08 PM
alswagg's Avatar
alswagg
Summit has a great "narrow" X pipe, Check out this link
http://www.summitracing.com/parts/sum-643125
Old Apr 10, 2013 | 08:27 PM
BPHORSEGUY's Avatar
BPHORSEGUY
Thank-you
Old Apr 10, 2013 | 08:29 PM
BPHORSEGUY's Avatar
BPHORSEGUY
It definitely is tight there, anyone use one of these on a C3?
