78 blower switch
Old Apr 6, 2013 | 04:47 PM
cjn1008's Avatar
cjn1008
Default 78 blower switch
blower motor only runs on high. when switch is in the low or medium fan speed position, nothing? changed out the switch, didn't help. any suggestions? doesn't matter what the slide switch is on (a/c, heat. vent) still only works on the high setting.
Old Apr 6, 2013 | 06:12 PM
Peterbuilt's Avatar
Peterbuilt
Below the valve cover in the center of the picture is the resistor, make sure you have a good connection there.
Just to the right is the relay, check those wires too.
Old Apr 6, 2013 | 11:05 PM
drwet's Avatar
drwet
Get yourself a wiring diagram and start following the power. In addition to the switch, there is a resistor and a relay as shown in the picture above and a switch on the vent selector. It can be a problem at any of these connections, or a defective part.
Old Apr 6, 2013 | 11:32 PM
my 76 ray's Avatar
my 76 ray
If you take that resistor out and turn it over, I think you will find that the two resistance coils attached to it are burned out. If that's the case, a new resistor will fix your problem.
Old Apr 7, 2013 | 04:36 PM
cjn1008's Avatar
cjn1008
Thanks for the Great ideas!!! I'll check them out and let you know if that resolves the problem..
Old Apr 9, 2013 | 03:21 PM
cjn1008's Avatar
cjn1008
wanted to post a follow-up. I replaced the resistor even though it was not burned up, just slightly coroded; made not differrence! I replaced the blower motor switch in the dash; no difference. finally, just replaced the Fan relay switch under the hood, Wammo!! That was it!
Thanks again for the help! Now, on to bigger and better challenges.
To 78 blower switch
