Ordering parts for a non-stock engine?
I got all the different codes and stamps off the block.
GM 25
3970010
1183
14j121790
V0921C
Unless, someone changed a lot of other stuff with the engine, belt setup and the like.
I am in a very similar situation as you. My car is a 74 with the same block casting. In that respect it is a good old small block chevy. So for example, not all small block cars used a return line on the fuel pump, 74 did so you can tell them you have a 74 vette if you need a fuel pump.
On corvettes, the power steering pump, brackets and pulley changed in 75. So it will depend on what was installed as to what year car you tell them you have if you need a ps pump.
For, me. If i need a starter, i say i have a 2000 Cadillac Escalade
power steering pump, i have a 75 corvette
transmission parts, i have an 87 monte carlo ss
rear end parts, 78 corvette
valve cover gasket, i have an 88 chevy truck
I did this to myself...
GM 25
3970010
1183
14j121790
V0921C
Just for fun, could you post a clear close up pic of your pad? I'm curious to see what vehicle it came from.
