Help with Gas Odor
Old Apr 10, 2013 | 03:21 PM
jackwabbit703's Avatar
jackwabbit703
Originally Posted by Tony Rags
hmmmm, sounds interesting. What did you have on that line before the filters were put there? Was it just an "open hose to atmosphere" to enable venting out??
It was just a piece hose hanging opened to atmo as you would call it and it stunk up the garage. After installing additional fuel line and 2 filters, no smells at all. Cost me 15 dollars for lines and filters at Autozone. The second filter will catch whatever over flown fuel from the first filter very well. Make sure to have have filters in angle so in case fuel over flows it will catch fuel deposits instead spilling it on the floor. I visually check the filters after each ride to see if there's any significant over flow but as to date it's NONE.
Here's a better picture before second fuel line and filter was installed. You can also clearly see the 90 degree nipple where the other end of this nipple is connection to the charcoal canister.
Old Apr 10, 2013 | 08:56 PM
commander_47's Avatar
commander_47
The vent line to the charcoal canister used to be where the fumes were forced through back into the carb to reburn.
Blocking of the vent line and adding a vented cap simply allows the pressure to stabilize and not force the fumes out through whatever is the least path of resistance. Since this was done, time to look elsewhere.
I find it very hard to believe that the overflow is the culprit. Just doesn't make any sense. The overflow is above all that. Also, why wouldn't my car make all those smells, and everyone else?
Does your car have the mechanical fuel pump replaced with an aftermarket or electric?
There is also a vent return line on the stock fuel pump to prevent vapor lock. If you changed your fuel delivery system did you block off this vent line?
Old Apr 10, 2013 | 10:25 PM
Tony Rags's Avatar
Tony Rags
Here's the description of the layout:
It's a brand new Eckler's replacement tank for the '78. The sending unit/filler neck is new also, along with a brand new vented cap. Because of the fuel injection, holes were tapped into each side of the tank (one for delivery at the bottom left, and one for return at the top right). The stock delivery/return tubes at the sender/filler are capped off. The vent tube from the sender/filler that goes to the charcoal canister has a short hose that goes to a vent fitting at the top of the tank to the left. From there, another hose is connected that was just an open vent to atmosphere. Thinking that was my problem, I capped that open vent hose. Still have the horrible gas odor....
Old Apr 11, 2013 | 09:27 AM
commander_47
Since you added fuel injection you must have an electric fuel pump.
It seems to me that if the easy stuff is ok, then the injection system needs to be looked at.
Gas in the exhaust pipes?
Old Apr 11, 2013 | 10:29 PM
Tony Rags's Avatar
Tony Rags
Commander,
Gas in the exhaust pipes? Tell me more. You may be on to something....
Old Apr 12, 2013 | 02:13 PM
commander_47
Normally, a faulty fuel injector will cause gas to flow unburned into the exhaust.
Also, a bad catalytic converter will cause a rich mixture.
The system is normally computer controlled. If this is the case, you need to check the specs for your application.
Also, does your system require a pressurized gas tank? Might be the hiss you hear.
