question on home alignment
Old Jun 19, 2002 | 07:58 PM
bob's Avatar
bob
Default question on home alignment
I have completed a full rebuild of the rear suspension and am at the alignment stage now. I have my rear camber where I want it and after the first adjustment have .020 toe in on the left and .100 toe in on the right. What do you guys use as final. I am looking at about .050 target but want to hear what others have been doing.
bob
Old Jun 19, 2002 | 09:12 PM
Scott78's Avatar
Scott78
Default Re: question on home alignment (bob)
Mine is set for .125 (1/8th inch) toe in.
Scott
Old Jun 19, 2002 | 09:35 PM
bob's Avatar
bob
Default Re: question on home alignment (Scott78)
Scott
Is that total or per wheel?
bob
Old Jun 19, 2002 | 09:40 PM
Scott78's Avatar
Scott78
1/8th on both sides so .250 total. In retrospect I think he could of gone less(alignment guy) maybe .125 total. But tire wear is even and not excessive.
edit for oops just dug alignment sheet out it was 1/8th total even split to both sides.
Scott
[Modified by Scott78, 7:45 PM 6/19/2002]
Old Jun 19, 2002 | 10:47 PM
Frank75's Avatar
Frank75
Don't forget to check that you're not "dog legging" i.e. rear wheels not lined up with front wheels. One way to do this is to project a laser beam from one of the new laser-levels onto the front spindle, or alignment gauge and make sure you're pretty well centered. Toe can be correct but both wheels can be pointing off into left-field somewhere...
To question on home alignment
