Need help...and so does my vette
Old Apr 10, 2013 | 07:20 PM
Chavlik's Avatar
Chavlik
Default Need help...and so does my vette
I have a 1980 Corvette in which I replaced the motor this past winter. it runs great above idle and on the road but will not idle for me. Any suggestions on which direction to look? timing appears to be okay at 32 to 34 degrees. I retained the stock carburetor which was running just fine before I swapped the motor. my mechanic friend doesn't work on carburated cars and is not sure which way to look. thank you in advance for all your suggestions.
Old Apr 10, 2013 | 07:38 PM
hugie82's Avatar
hugie82
Swap the carb out. Most likely during your engine change the carb got banged around or the fuel dried up inside causing a blockage in the orifices.
Old Apr 10, 2013 | 08:00 PM
Yellow1980's Avatar
Yellow1980
Had the same problem with my '80 3 years ago. I had a leak in the intake manifold.
Old Apr 10, 2013 | 08:37 PM
my 76 ray's Avatar
my 76 ray
Check for vacuum leaks before swapping or rebuilding the carb.
Old Apr 11, 2013 | 07:49 AM
Chavlik's Avatar
Chavlik
Thanks. I will check for leaks.
Old Apr 12, 2013 | 05:47 PM
Chavlik's Avatar
Chavlik
does anyone have any suggestions on the best way to detect vacuum leaks?
Old Apr 12, 2013 | 05:54 PM
Bagmup's Avatar
Bagmup
A can of carby cleaner with nozzle attached, squirt some in any place there's suspected vacuum leak. The engine will idle up if theres a leak and sucks some carby clean through.
I've also seen guys use a small gas torch (unlit of course) same principle, the gas will get sucked through the leak and idle up the engine.
Old Apr 12, 2013 | 06:21 PM
hugie82's Avatar
hugie82
I'm not as brave as I was, so I use WD40 to spray around. It's not as flammable as carb cleaner and washes off easy
Old Apr 13, 2013 | 02:43 PM
Chavlik's Avatar
Chavlik
Well I have drenched the engine bay in carb cleaner and get no difference. I do believe I am running real rich judging by the watering of my eyes. Will that affect my problem?
Old Apr 13, 2013 | 07:05 PM
my 76 ray's Avatar
my 76 ray
If it's running rich you should have some black smoke out the tailpipe. Try creating a vacuum leak by pulling off a vacuum line or two. If that helps it would confirm that you are running too rich.
To Need help...and so does my vette
