ECM screws?
Old Apr 13, 2013 | 03:39 PM
jso789's Avatar
jso789
Default ECM screws?
Hi all,
A while back I had to change the defective prom chip in my 81. I removed the ECM to do this and when I was putting it back in, two of the little rubber plug/nuts that the bracket screws thread into pushed through and fell out under the car. (Due to the rubber being 32 or so years old and very brittle) I was wondering if these little rubberized nuts and screws are available anywhere or am I s.o.l.? Because they fell through, they are too cracked to stay in place to properly hold the bracket in tightly now.
Old Apr 13, 2013 | 03:47 PM
TimAT's Avatar
TimAT
Your local hardware should have something that will work. There are lots of names for them. Some of them have a nut and sleeve inside the rubber. Push the insert into the drilled hole, insert a screw with a washer. Tighten the screw and it collapses the sleeve securing the nut into the hole.
