BBC : combustion chamber size recommendation
Old Apr 13, 2013 | 07:04 PM
couperdecar's Avatar
couperdecar
Default BBC : combustion chamber size recommendation
I have a chance to pick up a 396 bbc that was built for a blower, but currently has none. The current heads have 109cc combustion chambers and I believe the motor to be 7.5:1 compression. What size combustion chamber head would I need to get this old girl up to 9.5:1 Any thoughts would be appreciated. (38 cc was the smallest I could find)
Old Apr 13, 2013 | 09:06 PM
GS977's Avatar
GS977
if it has 7.5:1 comp. it has dish pistons. your gonna have to change the pistons and rebalance the rotating assembly.
Old Apr 13, 2013 | 10:01 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I'd have to agree, and say that you appear to be asking the wrong question. I'd stick with the more conventional sized chambers such as you already have and change the slugs to bring up your compression.
That said, depending on your piston/deck height and gasket thickness, 9.5:1 with 110 cc heads will require ~24 cc domes. Unfortunately, being that you're working with a 396, that may well require a custom order. Us 427 guys frequently run into a similar piston availability problem, despite its popularity.
Sorry, I know the above isn't exactly the info you are asking for, but figure you need to hear it.
Old Apr 13, 2013 | 10:42 PM
couperdecar
I was thinking changing out the iron heads to some 38cc aluminum ones might do the trick. So the 38cc heads wouldn't work?
I 'd have to have someone else r & r pistons = $$$
Old Apr 13, 2013 | 10:52 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
flat tops and open chamber will be 9:1
Old Apr 14, 2013 | 09:12 AM
ajrothm's Avatar
ajrothm
There are NO BBC heads with 38cc chambers... Not even possible.
Smallest you are likely to find are around 100cc edelbrocks... Then maybe mill them to mid 90s CCs. I still doubt you'll see 9.5-1 comp with flat tops.
Gonna have to put pistons in it.
I have a 454 that has flat tops, we used 69' model closed chamber oval ports, I believe they CCd at 107, then we cut them some. That motor is still barely 9.0-1.. Very mild.
Rat motors need some domes for sure..
Old Apr 14, 2013 | 10:55 AM
TheDucci's Avatar
TheDucci
If you can get the head casting numbers it would help take some of the guess work out.
Old Apr 14, 2013 | 11:53 PM
couperdecar
http://www.jegs.com/p/Edelbrock/Edel...37229/10002/-1
Let me ask the question another way. Does anyone know the relationship on a bigblock head for compression ratio when going to a smaller combstion chamber. I found a site for a sbc head earlier. I think they said that 10cc lower was worth a point.
If I buy this 396 I can recover some of the cost by selling the iron 109cc heads. If I pull the slugs - I can't recover anything and its not such a good deal. The 109cc heads are off a 67' 360hp bbc
Old Apr 15, 2013 | 12:40 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I think I'd be looking for an 8-71 blower to stick on it...or forget it and find a different motor. 396's are cool...and I've had some pretty fast ones..but a healthy smallblock will handle it...or find a 454 or something.
JIM
Old Apr 15, 2013 | 03:51 AM
Bagmup's Avatar
Bagmup
Centrifugal super charger
Old Apr 15, 2013 | 09:04 AM
Little Mouse's Avatar
Little Mouse
there were a gillion 454s put in 70s/80s pickups, rebuild one with higher compression pistons forget about the 396.
Old Apr 15, 2013 | 03:44 PM
7t9l82's Avatar
7t9l82
there is no replacement for displacement. i agree build a bigger engine.
Old Apr 15, 2013 | 09:22 PM
TheSkunkWorks
Originally Posted by couperdecar
...Let me ask the question another way. Does anyone know the relationship on a bigblock head for compression ratio when going to a smaller combstion chamber...
Sorry, no. Just too many variables for such a rule of thumb that works for all BBC configurations.
To BBC : combustion chamber size recommendation
