Off-set trailing arms !
Old Apr 14, 2013 | 12:11 AM
96Smoke-Eater's Avatar
96Smoke-Eater
Cruising
Default Off-set trailing arms !
Hello,
I have a 72 Stingray I was just wanting to get some opinions on installing a pair of Off-set trailing arms. I know what they do, they allow U to run a wider tire outback. But Is this mod something to really invest in ? Is it something that ever Vette owner should definitely do or not... I like the idea of some bigger meats on the back. Or should I just put my money in to a better mod ? Just wondering what the C3 community says about it....
Old Apr 14, 2013 | 04:55 AM
SuperBuickGuy's Avatar
SuperBuickGuy
IMO yes, it's worth it. Wider tires = better traction. They're also stiffer laterally, and it replaces your bushings - which, in a lot of C3s are perished.
Old Apr 14, 2013 | 06:27 AM
Hadez's Avatar
Hadez
You can run 18's and up on stock trailing arms. This is not readily known. Search for a post by "Gordon". 10" wide 17's will not work but 18's will.
Old Apr 14, 2013 | 09:25 AM
Tom454's Avatar
Tom454
Originally Posted by 96Smoke-Eater
Hello,
I have them on my 70. I run BFG 295-50's But I also lowered the bump stop on the frame. One thing I did notice though- I installed new diff side yokes and they wore down very quickly. Less than 8K miles and I have to re-place them again. Not sure if this is a quality control issue on the yokes, or a wide tire leverage issue. The yokes were the refurbed ones with the (supposedly) hardened insert. The bearings are fine.
Old Apr 14, 2013 | 11:14 AM
MacVette86's Avatar
MacVette86
I put the Vansteel offset trailing arms on because I had to replace/rebuild the original arms anyway. Figured I'd put on a brand new quality product that would also allow me maximum flexibility with tire/rim combos on the rear of my car.
Old Apr 14, 2013 | 01:17 PM
540 vette's Avatar
540 vette
Guys have put some really wide tire on their cars on the forum without them. I have 275´s on my car.
If you need wider backhalf your car.
Old Apr 14, 2013 | 02:39 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had 295's on stock trailing arm, anything bigger and your going to hit the frame before you run out of room with the off-set trailing arms. In reality they are now dinosaurs especially with the bigger wheel tire combinations available.
I run 285/40/18's on the back with no issues now with stock trailing arms. All the points we had to worry about with 15in. wheels are now gone, they are all inside the wheel now and the trailing arm is curved inward meaning there is more room as you move from the hub to pivot point.
Old Apr 14, 2013 | 04:58 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You can run a lot of tire with stock arms if you move the emergency brake cable tab (simple).
I've still got stock arms on my car and they're doing fine.
I bought a set of really nice offsets about 10 years ago. They hung on the wall so long I recently gave them to a buddy of mine.
JIM
Old Apr 14, 2013 | 09:34 PM
roscobbc's Avatar
roscobbc
Motorhead I run same sized rubber as you with 9" rim and 5" backspace on stock trailing arms. Measuring at the closest point to the inner fender/body there is about 1/2" clearance - sufficient enough one might think - however there are signs of 'polished' contact which I am going to guess is trailing arm flex/movement under extreme cornering - or perhaps flexing of the stock trailing arm rubber bushes. Its not really a significant issue with no indication on the tyres of contact - just makes me wonder if 'poly' bushes would help prevent this?
Old Apr 16, 2013 | 12:03 AM
RBrid's Avatar
RBrid
MotorHead, did you have to move the emergency brake cable tab with your 285/40/18 combination? Thx!
Old Apr 16, 2013 | 12:13 AM
Dirk76's Avatar
Dirk76
JIM
i have my t/a off. Does anyone have a berfore and after on the cable move.
Old Apr 16, 2013 | 01:11 AM
427Hotrod's Avatar
427Hotrod
Here's a pic of mine if you look closely. Pretty much just moving it from the side to the top.
JIM
Old Apr 16, 2013 | 08:12 AM
roscobbc's Avatar
roscobbc
JIM
Sorry to hi-jack thread - Jim now you have had the Wilwoods on the car a while - what are you thoughts about them - worth the additional cost?
Old Apr 16, 2013 | 11:32 PM
427Hotrod's Avatar
427Hotrod
I think they are a great product. They WILL help braking especially if you put sticky tires on it. And would really help if you installed larger diameter wheels and calipers/rotors. I wanted to stay with my 15" stuff...so there is only so much to work with.
Of course stock stuff does very well too if it's working well as we found out during the testing.
The quality of the Wilwood stuff is really good and makes a good addition. It all depends on what you're doing. If you're racing or using stuff hard..they make a lot of sense if for nothing else the weight savings and heat dissipation. If you are going to have to buy cores or pay to ship them back and forth, the Wilwoods get even more attractive.
Mine still has a rock hard pedal, no seeps or anything like that. Nothing to complain about...and I've definitely tested them well into the triple digit range a lot of times!
JIM
Old Apr 17, 2013 | 04:19 AM
aaroncorvette's Avatar
aaroncorvette
I have 17 x 9.5 rims with stock trailing arms (E - bracket moved), I don't see how I could fit more wheel under there as the tyre is 1/4 from the wheel well either side (285/40/17).
So personally I wouldn't bother with them.
Ignore the spring, it's not centred
Old Apr 17, 2013 | 08:33 AM
Tom454's Avatar
Tom454
Relocating the brake cable tab is easy if you can weld and have access to welding equipment. Otherwise... not so simple. I can weld & have welding equipment... but I chose to "indulge" and bought the offsets just... because.
To Off-set trailing arms !
