It's dead - won't start
Old Jun 20, 2002 | 12:58 PM
dewayne4
Default It's dead - won't start
It figures, I am ready to take the car to the body shop for paint, but it won't start or even turnover. I have no power to anything!!! It started and ran fine on Sunday. Now NOTHING... I have charged the battery for 2 hours and still NOTHING. Please help. :mad
Old Jun 20, 2002 | 01:01 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: It's dead - won't start (dewayne4)
Bad battery cable or connection...
Old Jun 20, 2002 | 01:03 PM
MikeC's Avatar
MikeC
Default Re: It's dead - won't start (427V8)
Old Jun 20, 2002 | 01:04 PM
dewayne4
I have disconnected the battery and cleande the terminals. Still NOTHING. Where is the ground on the frame on a 79 vette?
Old Jun 20, 2002 | 01:12 PM
MikeC's Avatar
MikeC
Right below the battery tray on the crossmember where the frame kicks up..... all corrosion is not seen!
I had a battery cable go bad from what was probably a small puncture in the cable..... the cable looked absolutely fine from the outside
Old Jun 20, 2002 | 01:18 PM
Koz
Guest
Posts: n/a
Does the battery show a charge? Just cause you charged it doesn't mean it took it.. If so you could use your jumper cables to create a new ground to help isolate the problem.
Old Jun 20, 2002 | 01:39 PM
MasterDave's Avatar
MasterDave
Moderator
Here we go again. This is the problem......the firewall connector has a bad contact. The little blade connectors inside are so small it's a wonder they ever worked. It's the large red wire. To prove it out, just jiggle/push/pull on it while someone tries the key. It'll fire, guaranteed. This is so common it's silly really. I finally hard wired mine a couple years ago and have not had a problem since. I soldered the same gauge wire on the engine side, pushed the wire thru the firewall and soldered it on the inside to the same large red one. :cheers:
Old Jun 20, 2002 | 02:11 PM
dewayne4
Default Re: It's dead - won't start (MasterDave)
OK so were is the firewall connector. Driver or passenger side, high or low. Appreciate the help
Old Jun 20, 2002 | 02:32 PM
MasterDave's Avatar
MasterDave
Moderator
I replied to your IM, you can do this. Let us know how it turns out. :cheers:
To It's dead - won't start
