Oil leak at temperature sensor
Old 04-21-2013, 10:08 AM
Blue73Shark
Blue73Shark's Avatar
Default Oil leak at temperature sensor
73 L82 4 spd. Oil is leaking around the temperature sensor on the passenger side. I have tightened it as best I can, but it still leaks. Before I remove and re-install, is there a gasket to install or should sealant be applied to the threads? Picture below. Thanks.
Fran
Old 04-21-2013, 10:38 AM
myk7
myk7's Avatar
Are you sure it's oil? Should be coolant if it's leaking. I just use a couple wraps of teflon tape on them.
Old 04-21-2013, 01:05 PM
my 76 ray
my 76 ray's Avatar
Or oil is leaking from the valve cover and spreading down to that area.
Old 04-21-2013, 03:10 PM
Blue73Shark
My brain fart. Oil is not coming from a "temperature" sensor. Valve covers needed a tightening. This will most likely solve the problem.
Thanks.
Fran
To Oil leak at temperature sensor
Quick Reply: Oil leak at temperature sensor
