1976 Corvette Stopped dead
Old Apr 23, 2013 | 11:54 AM
BBrown2324's Avatar
BBrown2324
4th Gear
Default 1976 Corvette Stopped dead
Hi everyone, I am new to this and just wanted to say thanks to everyone who can help me out. Yesterday while driving my car it was running great for 45 mins and all of a sudden the motor and whole car came to a sudden stop. So i attempted to restart the car and it turns over twice and then stops trying to turn over. Any ideas? Thanks
Old Apr 23, 2013 | 12:19 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Did you run out of fuel or oil?
Old Apr 23, 2013 | 12:22 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Check fuel filter, fuel pump, fuel lines
Old Apr 23, 2013 | 12:27 PM
BBrown2324's Avatar
BBrown2324
4th Gear
I have about 3/4 tank of fuel and the oil level is where it should be
Old Apr 23, 2013 | 12:29 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
I am guessing fuel pump or a fuel filter
Old Apr 23, 2013 | 12:38 PM
BKbroiler's Avatar
BKbroiler
It stopped in the first place because your ignition module failed. It stopped turning over because your battery is discharged, IMO.
Old Apr 23, 2013 | 12:39 PM
MelWff's Avatar
MelWff
Both the stopping and turn over could be a dead battey related to a non-functioning alternator. Did you notice the reading on the battery gauge before it died?
Old Apr 23, 2013 | 02:02 PM
scrappy76's Avatar
scrappy76
Lots of possibilities.
Step 1 charge battery, Try to start car , if it starts and runs, check to
see if alt is charging, if not replace alt. If it doesnt start go
step 2.
Step 2 spray starting fluid in carb to see if it starts. If it does, you
either a defective fuel pump or a clogged fuel line/filter. if it
doesnt start then go to step 3.
Step 3 if still doesnt start pull spark plug off plug, pull back coating,
hold next to metal. crank car to see if you have spark. If not
then its most likely your ignition module in your distributor.
Old Apr 23, 2013 | 02:45 PM
BBrown2324's Avatar
BBrown2324
4th Gear
step 2.
Im getting the battery tested and am buying new clamps because I noticed the ground was pretty lose. and if that doesnt work I will stry your other ideas. Thank you
To 1976 Corvette Stopped dead
