Starting a garaged 1972 Corvette
Old Apr 23, 2013 | 07:00 PM
Miccar's Avatar
Miccar
Default Starting a garaged 1972 Corvette
Hello,
I am a new 1972 Corvette owner as of last October. My car was garaged in late November and has not been started since. A new battery was installed in the car in October, before I purchased the car. In early January I disconnected the negative cable from the battery, but it was probably already drained by then. I also placed gas stabilizer in the tank before the car was stored. I plan on getting the car out of storage tomorrow. Is there any special way to get the car started after its been sitting this long? I imagine I will probably have to jump it to get it going, but is there anything else I should do? It's been many years since I had a car with a carburetor. Any starting tips would be appreciated. Thanks for the help guys!
Old Apr 23, 2013 | 07:16 PM
jhuff's Avatar
jhuff
make sure there is gas in the carburetor. If you can't hear or see gas come out when you open the throttle, you should fill up the float bowl before trying to start. Otherwise you will have to sit there and crank the engine until the fuel pump fills the float bowls.
Old Apr 23, 2013 | 07:23 PM
Mike Ward's Avatar
Mike Ward
Charge the battery, pump the gas to set the choke, turn the key and go.
Old Apr 23, 2013 | 07:39 PM
Miccar's Avatar
Miccar
Should I pump the gas pedal a few times then hold it to the floor while cranking the engine over?
Old Apr 23, 2013 | 07:46 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Don't hold it to the floor. Once you tap it to set the choke, if all is right with the settings it will fire up once the carb fills with gas. Mine sits for weeks to months at a time during projects and it eventually fires up. You hold it to the floor if it floods and needs to have plenty of clean air through it to clear the cylinders.
Old Apr 23, 2013 | 07:48 PM
Miccar's Avatar
Miccar
Thank you everyone.
Old Apr 23, 2013 | 08:24 PM
my 76 ray's Avatar
my 76 ray
You have to push the gas pedal to the floor ONCE to set the choke any time the engine is cold. For a warm start, try just cranking it first and only give it some gas if it doesn't start right away.
Old Apr 23, 2013 | 08:45 PM
Miccar's Avatar
Miccar
Thank you.
Old Apr 23, 2013 | 09:03 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
and post some pictures of your baby
Old Apr 23, 2013 | 09:18 PM
63split63's Avatar
63split63
Fully charge the battery, pump the gas pedal once to the floor and take your foot off , crank it for about 10 seconds ( or untill it fires ) wait 20 seconds , pump it once again and crank it for 10 more seconds, repeat untill it fires .
If you just keep cranking the starter for long periods without letting it cool you will damage it . Don't try to prime fill the float bowl unless you know what you are doing and keep the air cleaner on while you are trying to start the engine . You don't need a carb fire on a fiberglass car .
Bill
Old Apr 23, 2013 | 11:31 PM
Bagmup's Avatar
Bagmup
Old Apr 24, 2013 | 01:49 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Why not follow the starting procedures in your owner's manual? Might even be on the backside of the sunvisor, depending on model year.
To Starting a garaged 1972 Corvette
